Diablo 3.0 Power Options
Old 07-17-2012, 06:54 PM   #31
sterlib1971's Avatar
sterlib1971 is currently offline
My Year: 2003
My Model: SX8
My Engine: 3.0 Mercruiser
Gallery Images: 7
Send sterlib1971:
Default Re: Diablo 3.0 Power Options
Larry,
Are you playing wth your trim? When WOT, start trimming up small amounts at a time. You'll should notice and feel a difference. Find a happy medium on the trim by watching your speedo. When it starts getting to high, you'll definitely see it on the speedo / feel it. I have no problem w/42 mph - 44 mph w/my 3.0, depending on conditions.
-Brad
  • Old 07-17-2012, 07:05 PM   #32
    Check over the diaphram good for any signs of cracks or warpage. If none clean it up and give it a shot. Do a preasure test on it. Don't hold me to it but I think it should be around the 6-8lb reading.
    Larry
    Old 07-17-2012, 07:06 PM   #33
    sterlib ,
    I take it your talking to Gin?
    Larry
    Old 07-17-2012, 10:28 PM   #34
    My Year: 2003
    My Model: SX8
    Gallery Images: 7
    Send sterlib1971:
    Larry,
    Yeah, sorry. Looked at wrong name....
    Old 07-18-2012, 12:11 PM   #35
    Gin Time's Avatar
    Gin Time is currently offline
    My Model: 180 Diablo
    My Engine: 3.0L Alpha 1
    Send Gin Time:
    I've decided to clean up the fuel pump and keep it as a spare. A brand new one from Sierra is just $110. Small price to pay for piece of mind knowing I have a solid fuel system. New one gets picked up today so fingers crossed.
    1993 Mariah Diablo 180
    3.0 Merc / Alpha 1
    Old 07-18-2012, 02:12 PM   #36
    Excellent idea. Just remember to change out the filter too. That yellow line running to the carb is part of the USCG approved pump. It deverts the fuel from a blown out diaphram in the pump to the carb. Keeps it from dumping fuel into the bilge.
    IE: gas leak , fumes , boat go KABOOM!!
    Larry
    Old 07-20-2012, 12:36 PM   #37
    Gin Time's Avatar
    Send Gin Time:
    I took her out yesterday in about 1-2 foot seas and a good 10-12 knot wind. WOT @4800-4900 RPM was 36 with just me onboard and trimming the drive up. No smoke or smell. Responded very well and ran what I consider normal. The new fuel pump definitely cured her woes. I think taking her out with water like glass and no wind she will run at 40 no problem. I also changed the Racor 5510 fuel water filter and added a bunch of Sea Foam to help clean up the fuel and tank. I am sure there is bad fuel in there and perhaps some crud at the bottom of the tank. I plan on running her a lot over the next few days to try and burn through the tank. I got 3 extra filers so I will be changing them as I go as well.
    I have a 19 inch prop now and she is running high RPMs at around 4900 @ WOT. I am considering going up to a 21 pitch prop to reduce RPMs and increase WOT. No problems sacrificing some low end torque for an increase in WOT.
    3.0 Merc / Alpha 1
    Old 07-20-2012, 06:08 PM   #38
    Good to hear Gin!!
    Keep playing with her and she'll get better and better. Probably wouldn't hurt to change the oil again after you run thru maybe 3 tanks of fuel.
    I am glad to hear that you are getting happier with her!
    Larry
    Old 07-21-2012, 01:25 AM   #39
    Gin Time's Avatar
    Send Gin Time:
    Thanks Larry. We're going out for the day on the boat tomorrow. So psyched. Installing new switches in the am before we go out. I plan on doing at least two oil changes this summer. I am considering Amsoil or Royal Purple just to make sure I have some good quality oil protecting the engine.
    3.0 Merc / Alpha 1
    Old 07-21-2012, 01:55 AM   #40
    That's funny!!
    I've been running Royal Purple in the motor and drive of the last 2 boats I have owned , plus the Diablo I now have.
    I love the stuff even if it is a little pricey.
    Have fun!!!!
    Larry
    V8 engine options? shabah180 Original Mariah Talk 1 05-12-2012 01:12 AM
    5.7l engine options buchshot12000 Original Mariah Talk 0 03-26-2011 06:45 PM
    Engine Options - 2010 Mariah R19.9 Bailey James Sea Fox - Mariah Talk 1 07-14-2010 01:58 PM
    Diablo boat features & options peter Introductions 2 06-22-2010 01:35 PM
    Mooring anchors options 180diablo Boating 101 1 02-25-2010 10:32 AM
    There are 349 users
