Diablo 3.0 Power Options
Old 07-21-2012, 02:16 PM   #41
Gin Time's Avatar
Gin Time is currently offline
My Model: 180 Diablo
My Engine: 3.0L Alpha 1
Send Gin Time:
Default Re: Diablo 3.0 Power Options
Not related to power options but it's kicking my butt!! I am trying to install all new toggle switches but somehow lost power to the switches. I downloaded and printed the wiring diagrams on the forum but still cant make heads or tails out of this. I have power to the ignition but nothing to any of the toggles. Are the switches powered off the ignition key fob?
Does anyone know where the main power comes into the toggle switches??????
1993 Diablo 180
1993 Mariah Diablo 180
3.0 Merc / Alpha 1
  • Old 07-21-2012, 02:33 PM   #42
    Check your fuses Gin under the dash , on the right side behind the stereo, right at the gunnel area. You probably blew one there.
    Larry
    Old 07-21-2012, 02:39 PM   #43
    Gin Time's Avatar
    Send Gin Time:
    Yeah I checked them and replaced one. I noticed that I have two wires off my ignition switch going no where which may just have broken off with me fussing. One is red/pink which I believe is accessory ignition and the other orange w a but fuse mid line. Both have going nowhere. Then I have an orange and white coming in to nothing along with its black ground.
    3.0 Merc / Alpha 1
    Old 07-21-2012, 02:49 PM   #44
    Try this Gin
    http://www.mariahownersclub.com/foru...er-models.html
    If that doesnt give you the info let me know and I'll go look at mine down at the shop.
    Larry
    Old 07-21-2012, 02:58 PM   #45
    Gin Time's Avatar
    Send Gin Time:
    Originally Posted by ColoradoDiablo View Post
    Try this Gin
    Larry
    Thats PERFECT Larry! Thanks for all your help!! Fingers crossed. I have a sneaking suspicion that it may be the fuse block. Looks original and kinda cruddy. May head to West Marine for a new ATC Blue Sea fuse block after tracing these wires.
    3.0 Merc / Alpha 1
    Old 07-21-2012, 03:01 PM   #46
    That is exactly what I have planned too. A guy can't find glass fuses very easy anymore in a lot of places , and I never liked them anyway.
    Larry
    Old 07-21-2012, 06:31 PM   #47
    Gin Time's Avatar
    Send Gin Time:
    I installed the Blue Sea ATC fuse block and wala, everything works! All new switches, terminals and fuse block. Pics and info coming soon at my thread under projects.
    3.0 Merc / Alpha 1
    Old 07-21-2012, 06:46 PM   #48
    Awesome!
    Now ..........GO HAVE FUN
    Larry
    Old 07-21-2012, 06:58 PM   #49
    Gin Time's Avatar
    Send Gin Time:
    Awesome!
    Larry
    Ah yes. The fruits of my labor!!!
    3.0 Merc / Alpha 1
    Old 07-22-2012, 11:46 AM   #50
    Gin Time's Avatar
    Send Gin Time:
    Took her out for about 2 hours of solid tubing yesterday and boy what a great time we had! She is running solid and the issue of smoke and high temps is behind us. However, she still will not break the 33-36 MPH mark. This morning I removed the fuel filter at the carb and did notice some crud in there. Not a ton to cause a blockage but perhaps enough to hinder fuel delivery at WOT. Butt-head me removed the fuel filter and am now second guessing which way it goes in. Almost positive it goes in with the closed flat end out and the open end facing into the carb? YES?? no?? Ugggg
    3.0 Merc / Alpha 1
    V8 engine options? shabah180 Original Mariah Talk 1 05-12-2012 01:12 AM
    5.7l engine options buchshot12000 Original Mariah Talk 0 03-26-2011 06:45 PM
    Engine Options - 2010 Mariah R19.9 Bailey James Sea Fox - Mariah Talk 1 07-14-2010 01:58 PM
    Diablo boat features & options peter Introductions 2 06-22-2010 01:35 PM
    Mooring anchors options 180diablo Boating 101 1 02-25-2010 10:32 AM
    There are 281 users
