Diablo 3.0 Power Options
Old 07-15-2012, 03:23 PM   #21
Default Re: Diablo 3.0 Power Options
I know the feeling
Just take the cover off the carb so you can watch the hose where it connects to the flame arrestor. If you have another stint of getting warm , pull the thermostat when you get her home and make sure it isn't sticking.
Did you change the fuel filter yet? If not do it.
Larry
  • Old 07-15-2012, 03:34 PM   #22
    Gin Time's Avatar
    Gin Time is currently offline
    My Model: 180 Diablo
    My Engine: 3.0L Alpha 1
    Send Gin Time:
    I didn't change the fuel filter but I removed it and poured the gas from the filter into a container yesterday. Going to check it now.
    1993 Mariah Diablo 180
    3.0 Merc / Alpha 1
    Old 07-15-2012, 03:38 PM   #23
    If you can't blow thru it easy it needs replaced.
    Let us know how it goes!
    And above all else........enjoy the afternoon on the water
    Larry
    Old 07-15-2012, 03:49 PM   #24
    Gin Time's Avatar
    Send Gin Time:
    Yep, loves me my ethanol!!!
    3.0 Merc / Alpha 1
    Old 07-15-2012, 11:39 PM   #25
    Gin Time's Avatar
    Send Gin Time:
    Well we didn't make it out today due to some bad storms rolling in so I continued my hull wet sanding just above the waterline. Uggg
    Read through the Mercruiser owners manual and found out that the 3.0L is rated at 115HP. That could explain the lack of power.
    3.0 Merc / Alpha 1
    Old 07-16-2012, 02:13 AM   #26
    Jimh23 is currently offline
    My Engine: 3.0L Alpha I
    Gallery Images: 4
    Send Jimh23:
    I have a 180 Diablo with a 3.0 L engine. At 4600 RPM (highest recommend for the engine) it will get 38 MPH and at WOT (about 5100RPM) around 42 MPH with a 19 inch prop. With a 21 inch prop I would think the 40 -44 range is right. The engine is great on gas with a great range on a tankful. Things you can look at to improve your situation are: proper trim of the boat, 21 inch prop with loss of power on the low end, use mid range gas and add an additive to offset the ethanol. Consider changing fuel filters, spark plugs, distributor cap and a carb rebuild may be necessary if not done in many years. As for the heat problem I would look at a new impeller. The normal operating temp should be 150 for all speed ranges.
    Old 07-17-2012, 05:16 PM   #27
    Gin Time's Avatar
    Send Gin Time:
    Here are my latest findings. Did a compression test for 3 of the 4 cylanders (need an extension to get to the fourth). Test read 140, 150, 155. I found where the smoke was coming from.... the carb. Looks like the yellow tube which I believe is the blow back used to deliver fuel to the carb rather than the boat??? was clogged as well as where it attached to the fuel pump. I think this means the fuel pump is bad? Only weird thing is I didn't have any hesitation while opening her up.
    3.0 Merc / Alpha 1
    Old 07-17-2012, 06:19 PM   #28
    Can you shoot us a pic of that Gin?
    Larry
    Old 07-17-2012, 06:39 PM   #29
    Gin Time's Avatar
    Send Gin Time:
    Yes sir:
    Notice where I have the long screw. That port was totally clogged through to where the fuel comes in from the pump. I cleaned as much rust and orangey gunk out as I could with a screwdriver and that screw. I am not sure if WD40 is a good fit to clean more and remove rust and lube the spring. I would guess not since it is flammable and inside of a fuel pump, is, well.....
    Fuel delivery to the carb was fine. Can I clean out this pump and re-use?
    3.0 Merc / Alpha 1
    Old 07-17-2012, 06:52 PM   #30
    Gin Time's Avatar
    Send Gin Time:
    At this point I think I have hi-jacked this thread. ,) Sorry. Perhaps a moderator can move this to the projects section under the title "Gin Time Diablo Resto"?????
    3.0 Merc / Alpha 1
    V8 engine options? shabah180 Original Mariah Talk 1 05-12-2012 01:12 AM
    5.7l engine options buchshot12000 Original Mariah Talk 0 03-26-2011 06:45 PM
    Engine Options - 2010 Mariah R19.9 Bailey James Sea Fox - Mariah Talk 1 07-14-2010 01:58 PM
    Diablo boat features & options peter Introductions 2 06-22-2010 01:35 PM
    Mooring anchors options 180diablo Boating 101 1 02-25-2010 10:32 AM
    There are 362 users
