Power trim
Old 06-29-2010, 01:54 PM   #1
Chuck is currently offline
Send Chuck:
Default Power trim
My power trim works fine trimming up and even into the trailer mode, however it's hit and miss if it's going to work when pressing the trim down button. If you click it enough it will finally make contact and work...
What needs to be replaced and how difficult is it to replace??? Is the part a boat dealer item only or is it something that could be purcahsed cheaper at an automotive store???
  • Old 06-30-2010, 09:26 AM   #2
    Default Re: Power trim
    Hi Chuck, sounds like a dirty "down" switch or a faulty "down" solenoid may be the culprit here. Can you tell us what type on controller you have for the trim buttons? (a picture would help as well)
    Difficulty depends on how easy it is to access the trim pump (for the seleniod) or the switch contacts on the throttle assembly.
    mariah sx19 mercruiser alpha trim up trim gauge bad mrtransistor Mercury MerCruiser 1 08-05-2010 03:37 AM
    Not getting my power sweetness34 Mercury MerCruiser 3 09-10-2009 12:11 PM
    power trim pump fbinker Original Mariah Talk 3 04-30-2009 04:50 AM
    There are 302 users
