power trim pump
Old 04-26-2009, 04:42 AM   #1
fbinker is currently offline
Send fbinker:
Default power trim pump
Today when I checked the power trim oil level the oil was white, is this ok or do I have water in the oil. 1998 shabah 180 4.3. If I do need to change it is it a DIY job. thanks
  • Old 04-27-2009, 12:44 AM   #2
    22empire is currently offline
    My Model: 2000 Shabah 183 4.3L Alpha
    Send 22empire:
    Default Re: power trim pump
    White, well that definately means water in the oil.. And if there is water in it than probably you need a seal job..
    Old 04-27-2009, 12:29 PM   #3
    yep, definitely change the oil, and probably the seal as well. since you're a platinum contributor, you will find the "service, repair and installation manuals" section very helpful.
    Old 04-30-2009, 04:50 AM   #4
    Send fbinker:
    Thanks guys, I put on a new power trim resv. going to see if that makes a difference. noticed the old cap had a vent hole. I did get out as much old oil as I could. refilled with new trim oil and watched it mix with old white oil that was still in system. I did talk to a mercury tech today when I picked up my boat, he said not to worry about it. He fixed my powering steering. I guess some of fittings were loose and he put on new clamps.
    7.4l water pump edward cossey Projects 6 02-05-2015 02:53 PM
    trim moter and water pump Sudden Comfort Original Mariah Talk 4 01-15-2009 04:18 PM
    sump pump Digby Original Mariah Talk 0 07-30-2008 04:33 AM
    changing power steering pump 01DiabloMissouri Original Mariah Talk 2 07-09-2008 01:51 PM
    There are 332 users
