mariah sx19 mercruiser alpha trim up trim gauge bad
Old 06-07-2010, 03:04 AM   #1
mrtransistor is currently offline
Send mrtransistor:
Default mariah sx19 mercruiser alpha trim up trim gauge bad
down trim working but up not working?
push button for up get click but no pump motor action
I shorted the high current (big) terminals on the top (up) solenoid
Trim goes up
replaced trim up solenoid ($14 ebay)
trim working
turn key to start click but no start?
replace same type solenoid as trim but on top of motor
test/stuck in middle of nowhere? take off plastic cover short big screws with screwdriver to start motor with key turned on
trim gauge not working?
took cover off of starboard trim sender
pulled ceramic disc (careful) out twist and pull gently
looked clean grease ok
did not clean just pulled up the wiper contacts on outdrive a bit
for more pressure against resistance section (in grease)
left grease as is
push in
make sure trim gauge reads smoothly
make sure middle trim is middle of gauge
reinstall cover
test run boat I like prop blowout to show in black on gauge ( just above center)
  • Old 08-05-2010, 03:37 AM   #2
    Vacation Dave's Avatar
    Vacation Dave is currently offline
    My Model: 1995 Z220 Talari 7.4L Bravo I
    My Engine: 7.4L Bravo I
    Send Vacation Dave:
    Default Re: mariah sx19 mercruiser alpha trim up trim gauge bad
    mrtransitor,
    Thanks for the information on the trim. I don't know if it's the trim solenoid or the trim sendor. I have a 1995 Bravo I with 7.4L
    Where is the trim solenoid located? Do you have a picture?
    V Dave
    TRIM GAUGE INSTRUCTION Question? spinks99 Mercury MerCruiser 5 05-26-2010 02:50 PM
    Mercruiser Trim & Trailer system Richard Keirsey Mercury MerCruiser 3 08-05-2009 08:59 AM
    Mercruiser 454 with Bravo 1 - trim sensor cleah Mercury MerCruiser 8 10-01-2008 01:33 PM
    trim gauge no problem Original Mariah Talk 2 08-19-2008 09:18 PM
    Alpha 1 Trim sender repair Z 202 Mercury MerCruiser 2 08-28-2007 01:34 PM
    There are 316 users
