Alpha 1 Drive reservoir leak
Old 08-09-2012, 06:04 PM   #1
jwdmax is currently offline
My Engine: 5.7 mag
Send jwdmax:
Default Alpha 1 Drive reservoir leak
I have a 1994 Z212 Shabah. I have had a slow leak from the drive reservoir that I just had to top off the resi every couple weeks. Now the resi will not hold any gear lube for longer than an hour. There is no leak inside the boat. Seems to be seals inside the drive. There is a little oil in the water everytime I lower the boat off the shore station. Any help would be greatly appreciated. Also, does anyone have the merc service manual for this drive as I am sure I will be replacing seals? I do have a water pump repair kit with seals in it, maybe the seals I need are in this kit?
  • Old 08-09-2012, 06:38 PM   #2
    Default Re: Alpha 1 Drive reservoir leak
    Welcome to MOC.
    Sounds like you have seal issues. Make sure you don't have water in the drive! Ouch!
    Water Pump kit won't have the seals you need.. You really need to do a preasure test on the drive ASAP.
    Probably looking at reseal of complete drive(do both upper and lower) , no use in doing it twice.
    I definately would'nt run it anymore til you find the problem.
    Larry
    Old 08-13-2012, 12:25 AM   #3
    X2...
    Service manuals are available here on our site to contributing members. Click here to read up on membership benefits.
    leak in stern drive tem Original Mariah Talk 1 05-12-2011 08:30 PM
    Bravo 2 prop on a alpha 1 drive? dieselwiezil Prop Talk 1 07-14-2010 08:15 AM
    drive and leak berk1402 Boating 101 1 05-20-2010 03:10 AM
    Alpha drive cracked shoc Mercury MerCruiser 8 04-30-2009 08:31 PM
    Alpha Gen II Drive Coupler Captain Steve Mercury MerCruiser 3 10-22-2007 06:40 AM
    There are 277 users
