problem with Mercruiser 5.0 MPI
Old 07-03-2012, 11:47 PM   #1
TomasSE is currently offline
My Year: 2008
My Model: SC25
My Engine: 5.0L Bravo III
Send TomasSE:
Default problem with Mercruiser 5.0 MPI
On Saturday Mercruiser engine started to show non-standard behavior. I drove about 1 km, I knocked on the neutral, himself a dead engine. Again I started the engine was idling 400 rpm and irregular operation, alarm whistles. The temperature of the fine, fine lubrication, oil in bravo fine.
I found if I turn the key to the ON position the fuel pump runs all the time. (before the glitch pump shut off after 2 seconds after releasing ON).
Otherwise, the engine runs normally, full throttle in order.
Alarm beeps constantly.
Does anyone know what could it be?
Thank you. : (
  • Old 07-04-2012, 01:02 AM   #2
    Default Re: problem with Mercruiser 5.0 MPI
    Alarm issues are quite common Tomas. Have a look through this thread for answers.
    Old 07-04-2012, 08:43 AM   #3
    My Year: 2008
    My Model: SC25
    Send TomasSE:
    Yes I know that these issues are common. But I do not know why the fuel pump runs continuously (in the ON position), it is a safe mode?
    How do I reset the ECM unit 555 48 0708?
    Old 07-04-2012, 12:56 PM   #4
    Sigh.... i completely missed the fuel pump issue.
    Normally when the fuel pump is stuck on your fuel pump relay is stuck on, Try tapping/hitting on the relays a little to see if the pump will turn off with key on. You may need a new relay, The relays are on top of the engine.
    Old 07-04-2012, 04:01 PM   #5
    My Year: 2008
    My Model: SC25
    Send TomasSE:
    Yes there are 3 relays. I tried to measure, and they are fine, I also exchanged between relay. And still the same problem. It is a safe mode of ECM?
    Can I reset the ECM 555 0708 unit without a computer?
    Old 07-04-2012, 06:33 PM   #6
    You need a scan tool to read & reset the ECM.
    Old 07-04-2012, 07:01 PM   #7
    My Year: 2008
    My Model: SC25
    Send TomasSE:
    Can you please send me a web link where I buy scan tool and what model? Thank you,
    Old 07-04-2012, 07:55 PM   #8
    The Rinda tool is the only one i know of but i'm sure there are others. Here's a link but you might want to look around cuz its not cheap. You would probably be better off finding a local Marine mechanic & let him attach his scanner to your motor & diagnose the problem. If you decide to DIY you will likely also need a service manual for the 555 ECM.
    Old 07-10-2012, 08:48 PM   #9
    My Year: 2008
    My Model: SC25
    Send TomasSE:
    I want to buy a Mercruiser Scan Tool product from the manufacturer Rinda technologies. I wrote an email ([email protected]), but I still do not have a response from the Rinda.
    Can you tell me where I can buy products Rinda?
    Old 07-10-2012, 10:39 PM   #10
    Sorry Tomas but buying direct from Rinda or finding one on eBay is the only source i know of.
    Mercruiser 5.0 EFI engine problem timgordon Mercury MerCruiser 4 09-13-2011 01:22 PM
    Mercruiser 5.7L Q's dabates Original Mariah Talk 4 07-11-2011 03:05 PM
    mercruiser 5.7 problem Brownboy Boating 101 3 10-13-2010 04:03 AM
    Mercruiser 454 Magnum markkearns Mercury MerCruiser 2 07-08-2009 05:25 PM
    5.7 L Mercruiser 300sflyer Mercury MerCruiser 8 07-29-2008 04:42 PM
    There are 355 users
