drive and leak
Boating 101
Old 05-19-2010, 07:22 PM   #1
berk1402 is currently offline
My Model: talari200
My Engine: 5.7
Send berk1402:
Default drive and leak
I have a Mariah talari 200 with a 5.7 merc. I have had the boat for a month. I have 2 problems:
1] I have water coming in the boat. My auto pump comes on a lot. Does not apear to be coming from the motor. We checked that real well.
2] At take off the boat has a vibration.....shimmy??? But only at take off. The prop that was on the boat did have a piece out of one of the blades. I have replaced with a 4 blade.
thanks for any help!
  • Old 05-20-2010, 03:10 AM   #2
    Nathan5678 is currently offline
    My Model: Shabah 180 LE
    My Engine: 4.3l alpha
    Gallery Images: 8
    Send Nathan5678:
    Default Re: drive and leak
    Check all your bellows on the outdrive really close I just had a cracked shift cable bellows but could only see the tear with the drive fully up and turned all the way to port side. As for the shimmy I'm not sure but if the prop was out of balance it would only get worse as you increased your rpm not better.
    Thank you Nathan5678 for this useful post!
    berk1402 (05-20-2010)
    Gas tank leak syc92868 Original Mariah Talk 36 07-16-2013 01:56 AM
    3.0 Mercruiser Riser to Manifold Leak 1999Mariah Original Mariah Talk 2 06-12-2009 01:14 PM
    Fuel Tank Leak Roger Butterfield Mercury MerCruiser 10 05-27-2009 05:15 PM
    Greasing Drive jakejorgenson General Maintenance 0 02-03-2009 03:40 AM
    Found my small leak! Captain Steve Original Mariah Talk 3 10-05-2008 02:31 PM
    There are 366 users
