Bravo 2 prop on a alpha 1 drive?
Prop Talk
Old 07-11-2010, 04:07 PM   #1
dieselwiezil is currently offline
My Model: 2000 Mariah 212 5.7V8 Mercruiser Alpha I 21p mirage plus 48-13702
Send dieselwiezil:
Default Bravo 2 prop on a alpha 1 drive?
Will this adapt with the correct hub kit?
Quick Silver 48 - 15 1/4 x 19 on the dimensions and they only want a 100 for it and it is SS.
2000 Mariah 212 Mercruiser 350
2002 F150 Supercrew
1996 F250 Diesel lots of power goodies.
"Out of everything I have, I still prefer riding MARIAH"
  • Old 07-14-2010, 08:15 AM   #2
    Default Re: Bravo 2 prop on a alpha 1 drive?
    Hi dieselwiezi, I believe the bravo series props have a larger diameter body as the Bravo outdrives are larger than the Alphas so the prop body may not fit properly (too wide) within the Alpha's rear flange area.
    I would advise that you can try contacting Mercruiser for the correct answer.
    Alpha drive cracked shoc Mercury MerCruiser 8 04-30-2009 08:31 PM
    need new bravo three drive luv2boat Mercury MerCruiser 6 08-30-2008 09:54 AM
    Alpha Gen II Drive Coupler Captain Steve Mercury MerCruiser 3 10-22-2007 06:40 AM
    There are 297 users
