4.3LX bogs past 3/4 throttle
Old 09-09-2010, 06:43 PM   #1
dakotaman728 is currently offline
My Engine: 4.3LX w/ Alpha 1
Send dakotaman728:
Default 4.3LX bogs past 3/4 throttle
I have a 98 Shabah 180 with a 4.3LX. I replaced my plugs, cap, rotor, carb, fuel/water separator filter, removed old gas and filled up with new fuel. The boat starts fine and runs fine until I get past 3/4 throttle. The engine bogs whether i put it full throttle from idle or after cruising for a while. Any ideas? Ive been looking all over the internet and found nothing. My carb is an Edelbrock 1409.
  • Old 09-09-2010, 07:02 PM   #2
    skiater is currently offline
    My Model: Z182 Shabah
    My Engine: 4.3 merc
    Gallery Images: 3
    Send skiater:
    Default Re: 4.3LX bogs past 3/4 throttle
    Read of a similar problem somewhere on a boating forum.
    Turned out the fuel pick up tube screen inside the fuel tank had become partly clogged up, allowed gas through but not enough when the throttle was opened up.
    The owner was upset that the screen kept the gunk at the inlet end, nothing showed up in the fuel filter, their trouble shooting took longer because of this.
    Skiater.
    Old 09-10-2010, 07:55 PM   #3
    Send dakotaman728:
    Thank you!
    Old 09-11-2010, 04:16 PM   #4
    bbrophy58's Avatar
    bbrophy58 is currently offline
    My Model: 182 shabah
    My Engine: 4.3 alpha 1
    Send bbrophy58:
    I had the same problem with my 4.3. Replaced the same things you did plus new spark plug wires and it runs perfectly now. Try new wires.
    Old 09-11-2010, 10:31 PM   #5
    indykoch's Avatar
    indykoch is currently offline
    Send indykoch:
    Being the LX, I'd also question the second set of barrels on the carb. I believe that's about the area where they open up.
    I have no mechanical skills when it comes to carbs, so I'll let someone else chime in.
    Ryan
    Previously - '99 Z212 Shabah
    350 Mag MPI
    throttle issues murphysocc Mercury MerCruiser 5 07-07-2010 10:26 PM
    poor throttle responce Chriswilliams Original Mariah Talk 3 06-29-2010 11:25 PM
    Throttle handle roger simkin Mercury MerCruiser 1 01-01-2010 09:40 AM
    Throttle Arm assembly? trussman Original Mariah Talk 1 07-07-2009 12:08 PM
    Help: Engine won't rev past 2500 RPM pjp27 Original Mariah Talk 0 07-06-2009 03:24 PM
    There are 432 users
