spark plug help again
Old 09-03-2010, 03:24 PM   #1
aquaknot's Avatar
aquaknot is currently offline
My Model: z222 shabah
My Engine: 7.4l EFI-Bravo 1
Send aquaknot:
Default spark plug help again
I have a 99 7.4L MPI. I have replace my spark plugs with NGK BPR6EFS and the old ones are NGKR BR6FS. The threaded length is longer on the new one! Not sure isf I should start the boat! Help
Tod
1999 Mariah Z222, 7.4L MPI
2004 Lowe 16 ft aluminum, 25hp 4stroke
1995 pontoon 18 ft, 50hp mercruiser
198? aluminum 14ft, 6.6hp fisherman
  • Old 09-03-2010, 05:50 PM   #2
    aquaknot's Avatar
    Send aquaknot:
    Default Re: spark plug help again
    Had the marina xreferance the serial number of the engine and bpr6efs is the correct spark plug.why would the shorter thread br6fs beused by the previous marina. I hopeit hasnot caused a. Problem. Sorry for the grammar, using the wifes crackberry
    Tod
    Old 09-09-2010, 01:54 PM   #3
    recelect is currently offline
    Send recelect:
    If the marina says the ones you have now are the right ones, i would say you are ok. Using shorter threads I don't think will cause any damage, but i bet they were alittle less efficient, whereas using too long of threads could potentialy cause the cylinder heads to hit the spark plug, but if the marina says they are ok, then I would use them.
    Old 09-09-2010, 08:55 PM   #4
    aquaknot's Avatar
    Send aquaknot:
    thanx recelect, replaced the plugs last weekend and she runs like new. Team1marine & shabahz250 were correct............thanx again
    Tod
    Old 09-12-2010, 12:12 PM   #5
    Glad everything worked out for you!
    Oil plug???? jeffro788 Original Mariah Talk 11 08-26-2010 12:15 PM
    spark plugs aquaknot Original Mariah Talk 3 08-17-2010 07:57 PM
    Oil plug help Marci Sadler Introductions 3 05-16-2010 10:20 PM
    Spark plug MMarko Original Mariah Talk 1 03-16-2009 02:13 PM
    Which Spark Plugs? boarder1010 General Maintenance 2 07-22-2008 03:23 AM
    There are 328 users
