Power (motor) Trim
Old 09-08-2010, 07:29 PM   #1
bigmolilmo is currently offline
My Model: Talari 180
My Engine: 3.0
Send bigmolilmo:
Default Power (motor) Trim
Power (Motor) trim problems – Just got off the lake this last weekend over the Labor Day holiday and notice the motor trim would not go up or down, all it would do is click.
Tapped on the trim motor and solenoids, motor came up but would not go down. I replaced the two solenoids on the trim motor thinking they may have gone bad. Unfortunately the same problem just a clicking sound, I’m assuming the power trim motor may have gone out.
Anyone have any suggestions before I replace the power trim motor? Any Idea where I can pick one at a reasonable price?
Any help or suggestions would be deeply appreciated.
Big Mo
  • Old 09-08-2010, 10:39 PM   #2
    aaron999888's Avatar
    aaron999888 is currently offline
    My Model: 244 Jubilee
    My Engine: 7.4L Penta DuoProp
    Gallery Images: 38
    Send aaron999888:
    Default Re: Power (motor) Trim
    Disconnect the power trim motor and hook up the blue and green lead directly to a battery to test. If nothing, then its a bad motor. You can get after market motors from Sierra and possibly others for a lot less than the OEM parts. Check iboats.com
    Old 09-09-2010, 01:45 PM   #3
    recelect is currently offline
    Send recelect:
    Make sure you have a good ground to the trim assembly as well. if you replaced the solinoids and still only get a click, you might have a good enough ground to click the solinoids, but not turn the motor. Most likely though, the motor needs serviced, whether a rebuild or replacement...
    Old 09-09-2010, 02:22 PM   #4
    My Engine: 3.0
    Send bigmolilmo:
    Thanks, I will give it a try when I get off work this afternoon.
    Big Mo
    Old 09-09-2010, 02:29 PM   #5
    My Engine: 3.0
    Send bigmolilmo:
    I will double check the ground wires.
    Would you happen to know are they hard to rebuild, is there a place that rebuilds trim motors that I contact?
    Big Mo
    Old 09-09-2010, 03:15 PM   #6
    Gallery Images: 38
    Send aaron999888:
    Im sure that they are rebuildable. My guess is that it would cost about the same as having a starter rebuilt which seems to run about $100.
    You might check your local yellow pages for an electric motor sevice company.
    1999 244 Jubilee, 7.4Gi / Volvo DuoProp
    Old 09-09-2010, 03:48 PM   #7
    My Engine: 3.0
    Send bigmolilmo:
    Thanks for the info.
    Big Mo
    95 Mariah 180 Talri
    Trim Motor Doesn't Work - Clicks on Down but Nothing on Up Dredd Mercury MerCruiser 5 08-04-2021 06:08 PM
    Hydraulic trim motor question m&mmariah Boating 101 3 05-04-2010 09:06 AM
    Help with power sundeck/motor lid jasfiveo Original Mariah Talk 14 04-03-2010 11:05 PM
    There are 331 users
