Throttle Arm assembly?
Old 07-06-2009, 03:54 PM   #1
trussman is currently offline
My Model: 1994 Z235 Davanti 7.4L
Send trussman:
Question Throttle Arm assembly?
Went to the lake over the weekend and my boat would not start, I found out starting by jumping across the starter solenoid with a screwdriver, It seems like the neutral saftey switch (if there is one) is broken. The trottle arm has a lot of play in it also. Any info on a replacement would be appreciated or if you have any other ideas of what may be wrong would be helpful also. thanks in advance.
I have a 1994 Z235 Davanti cuddy.
  • Old 07-07-2009, 12:08 PM   #2
    Default Re: Throttle Arm assembly?
    This might be a job for your local Mercruiser mechanic to take a look at. Best to leave problems like this to the pros.
    throttle lever puzzle deblynlea Original Mariah Talk 4 09-25-2023 12:51 PM
    Trim switch on throttle Red Rover Original Mariah Talk 30 07-07-2022 10:41 PM
    Wanted: Transom mounted paddlewheel assembly WetWilly Mariah Parts For Sale & Wanted 4 03-13-2009 08:36 AM
    Power deck lid Assembly?? '93 Shabah 212Z Rick Original Mariah Talk 6 03-31-2008 05:26 PM
    Throttle and shifter question.. Jeff Barnett Original Mariah Talk 3 09-19-2007 12:30 AM
    There are 336 users
