Replacing Trailer Axle
Trailering and Tow Vehicles
Old 06-21-2013, 08:43 PM   #1
allz28's Avatar
allz28 is currently offline
My Model: z210 Shabah
My Engine: 5.7L Merc
Send allz28:
Default Replacing Trailer Axle
It appears I need to replace the front axle on my Chariot trailer. It's wearing the inside of the tires severely and the trailer doesn't appear to be out of alignment when I measure from the tongue. I also called a local trailer shop and they told me it's likely that I have a bent spindle and I should replace the axle.
So the problem is that I don't know where to buy one or what to order. There are a million websites for trailer axles (including the ones in the recommended resources). How do I know which will work with my trailer? If anyone has replaced theirs, I'd love to know how you determined fit. It seems like it's not as simple as measuring length.
1996 z210 Shabah
5.7L Merc/Alpha 1
  • Old 06-21-2013, 09:08 PM   #2
    Default Re: Replacing Trailer Axle
    Take a look here.
    They have lots of info.
    You need to know the trailer capacity from the tag. I bet you have 3500lb axles.
    Need to know length of axle , style of axle(straight , drop , torsion or leaf) , tube style(square or round) , and more.
    But they can , and will help you
    allz28 likes this.
    allz28 (06-21-2013)
    Old 06-21-2013, 10:09 PM   #3
    allz28's Avatar
    Send allz28:
    Thanks! I guess it won't matter that my current axles use bearing buddies and these use spindle-lube, right?
    1996 z210 Shabah
    5.7L Merc/Alpha 1
    Old 06-21-2013, 10:11 PM   #4
    Nope.......... doesn't matter , but I like the lube setup better.
    But the bearing buddies work great too. That's what I am running with no issues over 12 yrs I have used them.
    allz28 likes this.
    Replacing interior joshandsony Original Mariah Talk 7 08-08-2012 12:53 AM
    Replacing rollers on EZLoader trailer sanukc Trailering and Tow Vehicles 1 07-05-2011 05:38 PM
    replacing the belt littleray52 Mercury MerCruiser 2 08-13-2010 02:12 AM
    Replacing Bellows Paul Z General Maintenance 3 03-23-2010 04:43 PM
    Single vs. Tandem Axle Trailers Giffy Trailering and Tow Vehicles 7 07-29-2008 03:51 PM
    There are 318 users
