Replacing Bellows
General Maintenance
Old 03-17-2010, 01:25 AM   #1
Paul Z is currently offline
Send Paul Z:
Default Replacing Bellows
Have any of my Mariah friends tackled replacing the bellows on their boats. I'm not kidding myself, it's not an easy job. I'm mechanically adept enough to do it, but not sure about all part necessary to do a through job (seals, gaskets, special tools, etc). Appreciate your comments.
  • Old 03-18-2010, 02:04 PM   #2
    indykoch's Avatar
    indykoch is currently offline
    Send indykoch:
    Default Re: Paul Z
    Hey Paul! Find out, then let me know!!
    My bellows aren't bad, but I need to replace the u-joints soon and figured I'd replace these at the same time.
    You might want to consider the u-joints and/or gimbal bearing while you're in there with everything removed. I just had the gimbal bearing replaced a few years ago and really wish I would have had them do the u-joints as well.
    Ryan
    Previously - '99 Z212 Shabah
    350 Mag MPI
    Old 03-19-2010, 03:45 PM   #3
    Default Re: Replacing Bellows
    Hi Paul,
    Take a look at this great site with lots of info and tips (click here) and you'll get an idea on what's involved in changing the Bellows plus any special tools needed to do the job and indykoch is spot on with the Gimbal bearing and U-joints, now's the time to check them and lube or replace if necessary!
    Good luck,
    The Following 2 Users Say Thank You to WetWilly For This Useful Post:
    Dredd (03-23-2010), IowaWing (03-19-2010)
    Old 03-23-2010, 04:43 PM   #4
    In addition to Willy's informative site here's another one at MercStuff.com
    Dredd (03-23-2010)
    Paul Zingre Paul Z Introductions 1 02-26-2010 03:27 AM
    Paul Zinger Paul Z Mercury MerCruiser 0 02-26-2010 01:06 AM
    Paul Z Paul Z Original Mariah Talk 2 04-15-2009 09:05 PM
    Spring Tune up Paul Z Paul Z General Maintenance 0 04-13-2008 05:16 PM
    Paul Z Paul Z Introductions 2 02-28-2008 03:51 AM
    There are 333 users
