Tilt/Trim Trailer use
Sea Fox - Mariah Talk
Old 08-22-2013, 11:58 AM   #1
Lucky14's Avatar
Lucky14 is currently offline
My Year: 2004
My Model: SX19
My Engine: 5.0L Bravo I
Send Lucky14:
Default Tilt/Trim Trailer use
Ok one question I have is does the engine have to run to use tilt/trim and trailer modes to move the drive?
If you are in trailer mode do you push the trailer mode button again to get out of it or just trim down?
I think I messed with it the other day but didn't hear the hydraulic pump run... wonder if the eyelet is loose for the pump or an issue with the switch. I didn't have the engine running when I tried to take it out of trailer/tilt mode
  • Old 08-22-2013, 05:10 PM   #2
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Default Re: Tilt/Trim Trailer use
    Engine does not need to run...simply hit the down trim button to get out of trailer mode. You may have some corrosion on either the trim switch or on the contactor located on the trim pump.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 08-22-2013, 06:18 PM   #3
    Lucky14's Avatar
    My Year: 2004
    My Model: SX19
    Send Lucky14:
    Found it.. chaffed wire from the control lever to the pump motor B+ circuit... all working now after cutting out the chaffed and sodering and heat shrinking.
    Tilt/trim eyesore. OFD4546 General Maintenance 6 01-23-2014 12:31 PM
    Tilt/Trim jsewall82 Original Mariah Talk 29 08-30-2013 03:48 PM
    Trim/Tilt not working Shabah203 Original Mariah Talk 3 03-21-2012 07:06 PM
    transom Tilt and Trim switch dwmax Original Mariah Talk 4 08-31-2009 08:10 PM
    Operating with trailer tilt up? Billyclub Boating 101 2 05-26-2009 02:32 PM
    There are 332 users
