Trim/Tilt not working
Old 03-17-2012, 08:02 PM   #1
Shabah203's Avatar
Shabah203 is currently offline
My Model: Shabah 203
My Engine: Volvo Penta 4.3 GL Duo
Send Shabah203:
Unhappy Trim/Tilt not working
Hey all,
I've got a problem with the trim. Whenever you either trim up or down, you can hear the clicking of what I assume is the relay, but nothing happens. Not sure what to look for now so any suggestions are welcome. The boat is out of the water now, so it should be easy to work on.
It's a Shabah 203 with a Volvo Penta 4.3 GLX with the dual prop.
Thanks already!
  • Old 03-19-2012, 09:03 PM   #2
    Dredd's Avatar
    Dredd is currently offline
    My Model: MX-19 - Sold
    Send Dredd:
    Default Re: Trim/Tilt not working
    The clicking is probably the solenoids. It sounds like your motor might be bad.
    I had a similar issue a couple years ago: Trim Motor Doesn't Work - Clicks on Down but Nothing on Up
    Old 03-21-2012, 01:29 AM   #3
    mark43 is currently offline
    My Model: Z210 Shabah
    My Engine: 5.7L Bravo III
    Send mark43:
    It sounds to me like it is the solenoid. I mine would occasionally do that last year and when I had the boat winterized they replaced the solenoid and said it should fix the problem. Just a thought.
    Old 03-21-2012, 07:06 PM   #4
    Shabah203's Avatar
    Send Shabah203:
    Thanks guys. So the solenoids are (probably) the answer then. Anybody know if they are easy to replace yourself? Not sure where to look. Or do I need to change the whole motor?
    up trim not working michaelb Mercury MerCruiser 2 06-13-2011 12:42 AM
    Draining tilt,trim,fluid reservoir Douglas Alderman Mercury MerCruiser 20 05-07-2010 05:22 PM
    transom Tilt and Trim switch dwmax Original Mariah Talk 4 08-31-2009 08:10 PM
    Trim Tab not working. john elbro General Maintenance 4 07-28-2009 01:39 AM
    Non working trim switch River Man Original Mariah Talk 3 07-20-2009 05:19 PM
    There are 434 users
