SX19 4.3 hard start then no start after cable adjustment
Sea Fox - Mariah Talk
Old 08-08-2013, 09:14 PM   #1
Lucky14's Avatar
Lucky14 is currently offline
My Year: 2004
My Model: SX19
My Engine: 5.0L Bravo I
Send Lucky14:
Default SX19 4.3 hard start then no start after cable adjustment
the previous owner had the gear/throttle lever cables reversed. The remote would engage reverse in forward position and vice versa. I removed the remote swapped the throttle and gear cables.
The boat then started and ran, engaged and idled for a while.... and I shut it off. I buttoned everything back up and then it was hard to start. Crank 3 or 4 seconds then it would start sound health idle for 3 seconds then die. I pulled the flame arrestor off and the 2bbl looked ok some fuel could be smelt but I shot two quick spurts down the air horn, same thing crank for a while would start sound healthy then cut off.
I scratched. My had a it fiddle around thinking it might be the cut out before I messed with it I went to go again an wham-o no crank just the sound of a free spinning starter with no revolution of the engine. I spun the motor over by hand ok.. Tried a gain no luck.
I noticed the starter doesn't appear original as its labeled "Sierra" and isn't painted and has some noticeable corrosion on the back case of it. I gave it a thud with a hammer and no luck. I figure the be six went out.
I picked up a mercruiser starter, cap, rotor, wires, and NGK plugs since the secondary side of the ignition is all OE looking I figure cross my fingers hope it's a starter and tune it up a bit. Thoughts?
No loud abnormal noises were heard when it stopped turning over so I think the flywheel is ok.
  • Old 08-21-2013, 02:29 AM   #2
    Lucky14's Avatar
    My Year: 2004
    My Model: SX19
    Send Lucky14:
    Default Re: SX19 4.3 hard start then no start after cable adjustment
    I put a new merc. Starter in and cleaned up the eyelets on the solenoid. The flywheel was ok and the pinion was ok. I guess the bendix was stuck, the starter looked like crap all corroded. The starter was a Sierra brand?
    I also put new merc. Cap, rotor, wires, plugs in the engine. The parts were all original and the rotor button had nothing left to the electrode same with the plugs.
    The engine starts first revolution and is ready for my first boat outing Saturday if the weather holds.
    Old 08-22-2013, 09:06 AM   #3
    EricG's Avatar
    EricG is currently offline
    My Model: Z255 Shabah
    My Engine: 7.4l Bravo III
    Send EricG:
    Good luck and let us know how your first outing goes.
    _________________
    1997 Z255 Shabah
    Old 08-22-2013, 11:54 AM   #4
    Lucky14's Avatar
    My Year: 2004
    My Model: SX19
    Send Lucky14:
    Thanks.
    SX19 won't start and high pitch warning(?) noise 06_19SX Sea Fox - Mariah Talk 13 08-26-2023 01:26 AM
    Hard to start kriswd40 Boating 101 6 08-15-2012 11:53 PM
    Throttle Cable Adjustment??? berk1402 Mercury MerCruiser 0 07-06-2010 03:51 AM
    Hot start Hyperryd Mercury MerCruiser 2 06-25-2010 02:41 AM
    No trim, bilge blower, hard to start TJShabah Original Mariah Talk 3 08-30-2009 01:03 PM
    There are 356 users
