Hard to start
Boating 101
Old 08-14-2012, 06:55 PM   #1
kriswd40 is currently offline
My Model: Diablo
My Engine: 4.3 Mercury
Send kriswd40:
Default Hard to start
I have a 2001 Diablo with a 4.3 liter Mercury engine. I've routinely had issues getting the boat to start since purchasing it earlier this summer. I had a full mechanical check that found nothing wrong and replaced the battery upon purchase.
The engine has trouble turning over. I have to put the boat into neutral with the throttle wide open and then turn the key a few times in order to get it started. Some days I worry it won't start at all and I rarely turn the boat off once on the lake because I fear being unable to start while out.
Any times on things I can do to resolve this? I feel like I should be able to just turn the key and have it start, having to go into neutral and try several times feels like overkill.
  • Old 08-15-2012, 12:00 AM   #2
    truckingeorgia79's Avatar
    truckingeorgia79 is currently offline
    My Model: MX 200 Talari
    My Engine: 5.7L Alpha I
    Send truckingeorgia79:
    Default Re: Hard to start
    Mine had a similar problem, ended up just pulling the carb and rebuilding it. Put it back on and did the adjustments, what do you know it worked. Now i'm not telling you that's your problem, just giving you an idea. You could become a contributing member and all the books that you will need are at your finger tips.
    Jeremy
    1993 Mariah MX 200 Talari/ 5.7L Alpha I
    Old 08-15-2012, 05:03 AM   #3
    Sounds like possible choke issue to me. Is carbed or EFI?
    Larry
    Old 08-15-2012, 01:24 PM   #4
    My Model: Diablo
    Send kriswd40:
    Larry
    It's EFI... so unfortunately the carb suggestions won't work
    Maybe it is just in need of a long overdue tune up. Planning to do that at the end of the boating season (or start of the next) anyways.
    Old 08-15-2012, 03:20 PM   #5
    Dang , I'd take it to a merc tech so he can check it on the scan tool.
    Sorry , I'm not up too much with the EFI setups.
    One of our other members with EFI experience will chime in I'm sure
    Let us know what you find out either way.
    Larry
    Old 08-15-2012, 11:52 PM   #6
    Sorry my suggestion won't work. Hope you get it figured out.
    Jeremy
    Old 08-15-2012, 11:53 PM   #7
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    I would start with checking the fuel pump pressure and perhaps the coolant temp sensor.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    hard steering michaelb Mercury MerCruiser 2 05-20-2012 12:08 PM
    Hard starting 4.3LX mx20 Original Mariah Talk 3 10-06-2011 11:09 AM
    Hard starting 5.7L My 210 Talari Original Mariah Talk 9 09-29-2011 03:21 AM
    No trim, bilge blower, hard to start TJShabah Original Mariah Talk 3 08-30-2009 01:03 PM
    Hard steering Jimh23 Original Mariah Talk 4 06-05-2009 10:52 AM
    There are 329 users
