Throttle/gear lever
Sea Fox - Mariah Talk
Old 07-13-2013, 03:32 AM   #1
Lucky14's Avatar
Lucky14 is currently offline
My Year: 2004
My Model: SX19
My Engine: 5.0L Bravo I
Send Lucky14:
Default Throttle/gear lever
I am the third owner of the boat, as the story goes the first owner liked the "pimp" position, so he took the gear and throttle lever off and reversed the cable so towards the bow is reverse and aft is forward. How hard is it to make it "right"?
Can I just pop the linkage off from behind the panel or do I have to remove the entire assemble off the side of the boat then swap them around? I don't like the idea of having something like ... It's an accident waiting to happen
  • Old 07-13-2013, 03:54 AM   #2
    Default Re: Throttle/gear lever
    Sounds like more than likely they are reversed at the shift bracket on the motor.
    Check there first.
    Old 07-13-2013, 04:12 AM   #3
    Lucky14's Avatar
    My Year: 2004
    My Model: SX19
    Send Lucky14:
    That would be easier wouldn't it
    Old 07-17-2013, 03:25 AM   #4
    Lucky14's Avatar
    My Year: 2004
    My Model: SX19
    Send Lucky14:
    Ok I popped the engine cover looks like the throttle and shift cables go to a bracket on the starboard side of the engine. I suppose all this goofball did was swap the cables from their original position. Therefore, all I would have to do is to remove the cables from the bracket and swap them back. Such as putting the top on the bottom and the bottom cable on the top to restore it to forward=forward and pulling back =reverse? No other adjustments to the drive unit?
    Old 07-17-2013, 03:36 AM   #5
    If they did get switched , you need to follow the proper adjustment procedure.
    Bravo Cable Peplace
    Might be worth the money to take it to a Merc Shop to have it done professionally , if you are'nt up on it.
    They can be a bugger , especially starting from scratch.
    Old 07-18-2013, 01:49 AM   #6
    Lucky14's Avatar
    My Year: 2004
    My Model: SX19
    Send Lucky14:
    Mercruiser Alpha Shift cable adjustment - YouTube
    I think truly what the guy has done- is he disconnected the reverse gear cable and put on the forward pivot.
    Then took the forward linkage and put it on the reverse pivot. Reversing the cables would then actuate the push-pull action of the lever- therefore, reversing the drive engagement at the control handle.
    Thoughts?
    Old 07-20-2013, 01:49 AM   #7
    Lucky14's Avatar
    My Year: 2004
    My Model: SX19
    Send Lucky14:
    any thoughts?
    Old 07-20-2013, 02:07 AM   #8
    That would be my first inclination. Try reversing them and see what happens.
    Old 08-04-2013, 01:53 AM   #9
    Lucky14's Avatar
    My Year: 2004
    My Model: SX19
    Send Lucky14:
    Finally got out to the boat and tinkered... The linkage at the starboard riser can't be reversed the drive and the control cables have different trunnions. One has a hole in it and is held I with a tit on the lever area. The output drive cable's trunnion is held by a pocket.
    So the next thought is that the cable was reversed or located incorrectly at the control lever. So after breaking the "throttle only" button on the lever ( won't come out to remove the handle head and was brittle) it look like the throttle box had been out and apart before. It was tangled in the wiring harness and had shadow marks and scratches on the cover plate.
    The question to save me a lot of time does anyone have a picture of which cable goes where? There are 2 cable attacment points on earth position. Gven the two positions that each cable and can be in an upper and a lower, than at each of those positions there is a near and far arm.
    Old 08-04-2013, 02:38 AM   #10
    About the only thing I can suggest at this point is to get yourself the service manual for your particular engine/drive setup.
    The manuals are available to contributing members here on the site.
    You can read about the benefits here.
    Otherwise maybe one of the SeaFox Mariah guys can take a few pics for you.
    Sorry I can't help you out more lucky.
    throttle lever puzzle deblynlea Original Mariah Talk 4 09-25-2023 12:51 PM
    Throttle lever problem theeasynine Original Mariah Talk 8 04-06-2012 08:01 PM
    gear oil please help embasun Original Mariah Talk 2 12-05-2009 07:51 PM
    Mariah Gear Daxgirl Original Mariah Talk 9 05-08-2009 03:38 PM
    Little spring in trailor winch lever... kevo Trailering and Tow Vehicles 2 07-28-2008 06:28 PM
    There are 339 users
