throttle lever puzzle
Old 05-19-2009, 12:58 AM   #1
deblynlea's Avatar
deblynlea is currently offline
My Model: 2001 218 Shabbah 5.7L Volvo GS
Send deblynlea:
Default throttle lever puzzle
We have a 2001 Shabbah 218 with a 5.7 GS volvo and Penta SX outdrive. I just recently noticed a small rubbrer switch located on the forward control just ahead of the throttle lever. Can anyone tell me what that might be?
  • Old 05-19-2009, 03:23 PM   #2
    indykoch's Avatar
    indykoch is currently offline
    Send indykoch:
    Default Re: throttle lever puzzle
    That's your kill switch. There should be a lanyard attached to it. When you connect the lanyard to yourself, then happen to fall out of the boat (or even the seat), it pulls this switch and the engine will die and prevent the boat from becoming an unguided missile through the water.
    I don't attach mine to myself, but should. That's another debate for another thread. I'm on a tiny lake without much debris or waves, so don't really feel the need. However, I definitely don't condone it and would be the first in line to sue someone for not wearing it if they injured myself or family! Hypocrite??? Yes, definitely. But again, I'm an idiot and SHOULD use it!!
    Ryan
    Previously - '99 Z212 Shabah
    350 Mag MPI
    Old 05-19-2009, 03:33 PM   #3
    indykoch's right. The Mercruiser and Volvo throttle levers have kill switches attached. The models with the Kiekhafer throttle & shifter levels have a seperate kill switch the lanyard attaches to. I usually don't wear mine unless I'm exceeding speeds over 40mph, in seas higher than 3 ft, or if I feel I'm in danger. It's a great safety feature.
    Old 09-22-2023, 12:52 PM   #4
    jrazey is currently offline
    My Year: 2005
    My Model: DX212
    My Engine: Mercury outboard 150 H
    Send jrazey:
    I also just noticed a SWITCH just forward of the throttle has a switch right below and in front of the throttle. If this is a "KILL SWITCH" it does not have anywhere to attach a lanyard. If that is what it is then should it be in the UP or DOWN position for normal operation? I was wondering if it was a CHOKE of some kind to supplement the choke function that is supposed to activate by pushing in the ignition. Any additional input on that would be welcome. Thanks in advance. Jeff
    Old 09-25-2023, 12:51 PM   #5
    GregT is currently offline
    My Model: Z275ST
    Gallery Images: 7
    Send GregT:
    Yours is probably similar to mine, it is a kill switch and the lanyard it uses has a plastic clip on the end that clips on the toggle handle. It is a old design and newer designs work better, so you may consider swapping it out with a new kill switch and lanyard, it is just two wires on the backside to connect. This is on my to-do list also.
    Throttle Control - Mercury recall bdbyrnes Original Mariah Talk 2 09-02-2011 08:39 PM
    Throttle Body Restriction?? Jeff Barnett Mercury MerCruiser 13 08-31-2011 02:20 PM
    Throttle Control Shifter Question? Douglas Alderman Original Mariah Talk 21 06-25-2009 07:44 PM
    Little spring in trailor winch lever... kevo Trailering and Tow Vehicles 2 07-28-2008 06:28 PM
    Throttle and shifter question.. Jeff Barnett Original Mariah Talk 3 09-19-2007 12:30 AM
    There are 293 users
