top speed and rpms
Prop Talk
Old 08-05-2013, 07:13 PM   #11
Default Re: top speed and rpms
Sorry ,
WOT=Wide Open Throttle
As far as the conversion.............it all boils down to how much you like your boat!
You might want to just keep this boat for awhile , and later trade it in on a bigger one.
Everybody that has a boat always gets the 2 ft syndrome.
After having a boat we all want one bigger and better.
That's just the boaters life cycle.
Andy...........what was I thinkin'
Time for a beer and a nap!
EricG likes this.
  • Old 08-05-2013, 07:17 PM   #12
    jknotts's Avatar
    jknotts is currently offline
    My Model: shabah
    My Engine: 3.0 alpha 1
    Send jknotts:
    well....if i have a female and 3 kids in the boat it runs about 30 and turns about 42-4300 rpm and if im by myself it says its turning 6000 but i find that hard to believe cause the motot doesnt sound as its turninv that hard.
    Sent from my DROID RAZR using Tapatalk 2
    Old 08-05-2013, 07:21 PM   #13
    Andy b's Avatar
    Andy b is currently offline
    My Model: Diablo 180
    Gallery Images: 9
    Send Andy b:
    Originally Posted by jknotts View Post
    i also have access to a 4.3 with everything i need to swap it over for $500 but ive reaf in different forums that its not worth the time swapping it over for the little gain i would get cant really get a clear answer on this ? either lol
    I personally wouldn't have the 4 banger in my boat!
    As a guild i'm getting a steady 50mph (GPS) from my boat in the right conditions,
    But TBH it's a fools quest!
    I use my boat on the salty stuff and everyday is different with tide and wind conditions.
    If you get fixed on top speed you'll only be disappointed on the days you don't hit it...
    Of course it's probably a bit different running on fresh water lakes where the conditions are a lot less variable.
    don't do that or you'll be fitting the 4.3 sooner than you might wish.....lol
    Old 08-05-2013, 07:25 PM   #14
    Take a look at the post "mikeyt" made here.
    He explains about resetting the tach.
    I'd try that first.
    Old 08-05-2013, 07:25 PM   #15
    jknotts's Avatar
    My Model: shabah
    Send jknotts:
    well ill be keeping this kne for a few years. gonna get the vehicles and house paid for (3 more years) and gonna want to upgrade to at least a 23' with big v8 as ive street raced lots in the past and love my v8's lol. just wanna get it before im to old to enjoy haha
    Sent from my XT907 using Tapatalk 2
    Old 08-13-2013, 11:36 AM   #16
    lumbercitybravest's Avatar
    lumbercitybravest is currently offline
    My Model: 225 davanti
    My Engine: 5.0l alpha
    Gallery Images: 4
    Send lumbercitybravest:
    According to my prop guy who has 30 years in the industry, There is no such thing as a free lunch....At first I had no f***ing idea what the guy was talking about until he broke it down for me....WOT top speed is kind of a joke. If you do 30 MPH top end, you will wanna do 40, when you hit 40, you will wanna do 50 and so on and so forth....2 of the same props on 2 comparable boats could run entirely different. If you have a local prop shop, see if they will let you try out different props and once your tachometer is fixed, get a baseline on what you have. Being a 3.0 litre, your best bet would be some smart tabs FIRST with the prop you have, then go from there. Tons of good info on props and RPM range on here so it's well worth your while to do some research on the forums.
    Old 08-14-2013, 05:39 AM   #17
    husker_fan's Avatar
    My Model: 192 Barchetta
    My Engine: 4.3L Alpha I
    Send husker_fan:
    I had a 3 blade 19" on mine and went to a 4 blade 17". The majority of my time is spent towing kids and wife around or a little cruising. Hitting 60 in a boat doesn't excite me much. I'd rather have the boat excel where I'm using it. Mine won't hit 40 mph with the prop change now, but it has a deadly hole shot and almost instant plane. I cruise along about 3500 rpm with the towables. Couldn't be happier with it.
    Old 08-14-2013, 07:13 PM   #18
    rainman55343 is currently offline
    My Year: 2003
    My Model: sx 19
    My Engine: 5.7 alpha 1
    Send rainman55343:
    If its reading 6000 rpm's your rpm isn't reading right. On back of rpm gauge there is a switch for 4 6 and 8 cylinder engines.yours is probably set up for a different engine size. I have a v8 and I had to move the dial to v8. It was at a v6.
    5.7 cutting out at 3k rpms John Rush Mercury MerCruiser 11 08-14-2016 09:14 PM
    98 180 WOT RPMs, Speed anguspoe Original Mariah Talk 28 06-07-2011 09:32 PM
    Need lower end power but rpms already high jefros Prop Talk 4 09-04-2010 04:42 AM
    Top speed and RPMS tiger-rag Introductions 1 06-29-2010 09:55 AM
    High RPMs gcvaldez Prop Talk 4 07-25-2008 10:43 PM
    There are 252 users
