Tach reading off?
Old 05-17-2011, 02:56 PM   #1
jlshack is currently offline
My Year: 06
My Model: SX18
My Engine: 3.0 Alpha One
Send jlshack:
Default Tach reading off?
Took my SX 18 out on the river on the 10th and all went well with one new odd problem. The engine (3.0L) tachometer was reading about 1000 RPMs high thru out the scale. At idle, instead of reading around 600 to 800 RPMs the tach was reading around 1800 to 2000 RPMs, the engine was idling normally. And at all speed ranges, the tach consistently read about 1000 RPMs higher than it should. Any ideas what could cause this? Thanks.
  • Old 05-17-2011, 05:20 PM   #2
    Default Re: Tach reading off?
    Access the back of the tachometer and you should find a small dial that says 4 - 6 - 8 etc. Spin the pointer a few times and then set it at 4cyl. Sometimes they just go a little funny & lose their brains then need to be reset. IF that doesn't work i believe your Mariah uses Faria gauges which come with a lifetime warranty from the manufacturer.
    jlshack (05-19-2011)
    Old 05-19-2011, 01:18 AM   #3
    My Year: 06
    My Model: SX18
    Send jlshack:
    Great, I'll give that a try.
    Old 09-12-2012, 07:26 PM   #4
    thresher7 is currently offline
    Send thresher7:
    I'm new to this ... excuse me if it's redundant. We've a 1997 Z-276 with a 454. The tach, regardless of engine speed goes bazerk to the point of pegging itself in both directions... Is it safe to assume the same issue, if i remove the access panel, there'lll be a switch i can switch back and forth to see if that's the issue?
    Old 09-13-2012, 03:23 AM   #5
    Yep. It doesn't solve all tach problems but its worth a try.
    Old 09-13-2012, 08:27 AM   #6
    Send thresher7:
    Mike, later today I'll take the access panel off and give it a try... thank you... worse comes to worse this winter I'll take the tach out and send it off... thank you
    Old 09-13-2012, 01:57 PM   #7
    Make sure you check the connections also. There might be a poor one or a wire thats being pinched or near broken somewhere causing the bouncing around.
    speedometer reading zero mrtransistor Mercury MerCruiser 0 06-07-2010 02:48 AM
    2000 Z 272 Tach garyg Projects 5 12-16-2009 07:14 PM
    4.3L V6 Oil Dipstick Reading? SEMIJim Mercury MerCruiser 3 07-14-2009 10:23 PM
    Tach not working John Michael Myers Original Mariah Talk 4 06-30-2009 07:46 PM
    refurbished Tach jeffryb Original Mariah Talk 2 05-09-2009 05:19 PM
    There are 259 users
