Prop recommendation
Prop Talk
Old 09-04-2013, 08:32 PM   #1
donb is currently offline
My Model: Z182
My Engine: 4.6 alfa
Send donb:
Default Prop recommendation
Any recommendations on a different prop. Wouild like a better holeshot for pulling tubes and skiers.
1999 z182 shabah 4.3 Alpha 1.It has an aluminum prop on it now, must be the stock type
Any Info would be great, thanks
Last edited by mikeyt; 09-04-2013 at 10:27 PM. Reason: moved to new thread / proper forum
  • Old 09-04-2013, 10:27 PM   #2
    Default Re: Prop recommendation
    "Must be the stock type"?? What is the 'stock type" ?? We need a little more info about your existing prop's pitch? Number of blades? WOT rpms?
    I'm going to suggest that you take a few minutes to view the "STICKYS" at the top of the Prop Talk Forum. If you still have questions, i'll be happy to help you out.
    Prop Guru's... help me Identify this Prop - pics attached nglauer Prop Talk 19 06-19-2013 06:25 AM
    2000 Z182 prop recommendation needed Jgustman Prop Talk 3 08-13-2012 02:46 AM
    1999 Shabah 202 Cover Recommendation mcgilend Original Mariah Talk 1 11-18-2010 02:03 PM
    Bilge pump recommendation paulnpaula Original Mariah Talk 1 04-15-2010 11:20 PM
    Need Prop Recommendation dleeg5199 Prop Talk 5 06-15-2009 03:39 PM
    There are 319 users
