top speed and rpms
Prop Talk
Old 08-05-2013, 06:16 PM   #1
jknotts's Avatar
jknotts is currently offline
My Model: shabah
My Engine: 3.0 alpha 1
Send jknotts:
Default top speed and rpms
guys in need of a little info here. i have the 18' shabah with the 3.0 and was trying to get a little info on the best prop u have found for this paticular boat and what kind of top speed youre getting out of it and what rpm range is best.
Sent from my DROID RAZR using Tapatalk 2
  • Old 08-05-2013, 06:17 PM   #2
    jknotts's Avatar
    My Model: shabah
    Send jknotts:
    Default Re: top speed and rpms
    by the way its a 2000 model
    Old 08-05-2013, 06:33 PM   #3
    Welcome to MOC jknotts!
    If you'll look HERE there is a ton of info on props , WOT , & top speeds.
    Also if you do a search , there is a ton more.
    There is a few members who have your setup. "Andy b" is one that comes to mind right off the bat.
    According to the 2000 Mariah brochure , your Shabah with the 3.0l will run 40-46 mph. But.........that is in optimal conditions with not more than half a tank of fuel and maybe 2 people on board.
    Usually , the 19p 3blade aluminum prop is what was used for their testing if I remember right.
    Old 08-05-2013, 06:36 PM   #4
    jknotts's Avatar
    My Model: shabah
    Send jknotts:
    k thanks for the info. i have a 14.5x19 on mine but think its older and slightly bent so therefor its flexing a bit causeing me to lose on top and bottom end. its having trouble pulling out of the water and doesnt run but about 32-35 on top with just me and cooler in boat. im looming at the smart tabs everyone else is talking about to just trying to get some opinions thanks
    Old 08-05-2013, 06:38 PM   #5
    They are the only way to come out of the hole quick.
    Been using them for years.
    Old 08-05-2013, 06:39 PM   #6
    What is your WOT at that speed?
    Old 08-05-2013, 06:41 PM   #7
    jknotts's Avatar
    My Model: shabah
    Send jknotts:
    dont mean to sound stupid but ive been tryin to figure out what wot means lol
    Old 08-05-2013, 06:46 PM   #8
    jknotts's Avatar
    My Model: shabah
    Send jknotts:
    i also have access to a 4.3 with everything i need to swap it over for $500 but ive reaf in different forums that its not worth the time swapping it over for the little gain i would get cant really get a clear answer on this ? either lol
    Old 08-05-2013, 07:08 PM   #9
    Andy b's Avatar
    Andy b is currently offline
    My Model: Diablo 180
    Gallery Images: 9
    Send Andy b:
    I've got the 180 Diablo with a 4.3L Volvo Larry
    Do keep up
    Old 08-05-2013, 07:11 PM   #10
    Dozer's Avatar
    Dozer is currently offline
    My Model: Z202 shabah
    My Engine: 5.0 liter alpha 1
    Send Dozer:
    WOT-wide open throttle.
    5.7 cutting out at 3k rpms John Rush Mercury MerCruiser 11 08-14-2016 09:14 PM
    98 180 WOT RPMs, Speed anguspoe Original Mariah Talk 28 06-07-2011 09:32 PM
    Need lower end power but rpms already high jefros Prop Talk 4 09-04-2010 04:42 AM
    Top speed and RPMS tiger-rag Introductions 1 06-29-2010 09:55 AM
    High RPMs gcvaldez Prop Talk 4 07-25-2008 10:43 PM
    There are 354 users
