Fariah depth gauge works....sometimes
Old 07-21-2014, 02:32 PM   #21
Txtruckerpaul's Avatar
My Model: Z240 talari
My Engine: 7.4 bravo III
Send Txtruckerpaul:
Default Re: Fariah depth gauge works....sometimes
Morning, Larry,
Got the boat out yesterday and tried out the new depth finder. It started working as soon as I got it in the water. After a little while, it would flash 0.0 if I was sitting still or idling around. When I sped up and planed out, it would start giving correct readings.turning it off an back on had no effect. Can't figure this one out. ??? Have been curious too about the top speed of the boat, so I got a GPS and got a top speed of 48mph with 5 people onboard but still has that wot bog. I can get it almost all the way open, but put the throttle all the way down it it bogs out. Very annoying, but that's a different problem to fix on another day. Any ideas about the depth gauge?
  • Old 07-21-2014, 02:58 PM   #22
    roger rowley is currently offline
    My Model: 238 shabah cuddy
    My Engine: 5.7gsi volvo penta /sx
    Send roger rowley:
    Whats a wot bog? Pls enlighten me as to these American colloquialisms sweet patch,in the hole ext, I have seen on this site "fascinating"
    Old 07-21-2014, 03:17 PM   #23
    Send Txtruckerpaul:
    Roger, it's wide open throttle bog. When I open the throttle up all the way, the engine loses all power and acts like it want to die
    Old 07-21-2014, 03:33 PM   #24
    Paul ,
    Did you set the keel offset on the unit?
    Does it stay at 0 with engine off?
    Old 07-21-2014, 03:43 PM   #25
    Send Txtruckerpaul:
    I set the keel offset at 2ft. Just tried something with a weird result- boat is on the trailer at home. Filled the bilge full of water from the garden hose. No change in the 0.0 flashing. Didnt expect that to change since it's on the trailer. Got the water level above the transducer. I unlocked the transducer from the base while submerged and immediately got a steady reading of 1.6 and the shallow alarm started going off (I had that set at 4ft). I did fill the base with 2.4 oz of anti freeze like the instructions said. When I unlocked the transducer from the base, it filled with water and began reading steadily. Think it might not have had enough antifreeze in it?
    Old 07-21-2014, 03:47 PM   #26
    Let us know.
    Old 07-21-2014, 03:50 PM   #27
    Send Txtruckerpaul:
    I sure will. It'll be the weekend after next before I can get her back on the water again (on call at work). Have a water pump to replace and maybe an alternator, too, in the meantime.
    Old 07-21-2014, 04:12 PM   #28
    Send roger rowley:
    Thank you Paul, got that. Incidentally re the anti freeze I switched from that to mineral oil [a laxative from the pharmacy believe it or not] a bit thicker still go's 7.2 7.6 6.8. I must have al lot of fish in my river or its back to the drawing board.
    Old 07-21-2014, 04:28 PM   #29
    Send Txtruckerpaul:
    Welcome, Roger! I have heard of some udon mineral oil and other use the ethylene glycol (anti freeze). The instructions I have from faria with my new depth finder says to use the anti freeze, but airmar, who I believe manufactures the transducers for faria, says to use mineral oil. If mine still isn't working right on my next trip out, I'll try the mineral oil. Just for kicks and giggles, I may ask my pharmacist for a bottle of transducer laxative. Hahaha
    Old 07-21-2014, 04:34 PM   #30
    Send roger rowley:
    Gives the expression go's like **** a whole new meaning!!
    Engine Hour Gauge and Depth gauge J Thornton Original Mariah Talk 5 08-21-2013 01:45 AM
    Depth finder gauge Jaztwnz General Maintenance 11 05-15-2013 06:39 PM
    Depth Gauge michaeltrotta Original Mariah Talk 3 07-18-2012 07:06 PM
    Depth Finder works the first minutes then mad ebb8827 Original Mariah Talk 8 03-23-2010 03:52 PM
    Useful Info on Fariah Depth Sounder Z275 Original Mariah Talk 11 05-28-2008 10:17 PM
    Total Members: 18,991
    Total Threads: 13,324
    There are 253 users
