Fariah depth gauge works....sometimes
Old 06-23-2014, 12:09 PM   #1
Txtruckerpaul's Avatar
My Model: Z240 talari
My Engine: 7.4 bravo III
Send Txtruckerpaul:
Default Fariah depth gauge works....sometimes
Hi all. Finally my talari running good, but noticed yesterday at the lake that the in dash depth finder has a mind of its own. Most of the time it would show the depth reading, but then it would start flashing a zero for a few minutes and other times the readout would just be blank, then start working again. I checked wires, connections, etc. didn't matter if the boat was running or not. Any ideas?
  • Old 06-23-2014, 01:04 PM   #2
    Default Re: Fariah depth gauge works....sometimes
    Transducer has come loose from the hull Paul , more than likely.
    It's under the engine.
    Do a search "Depth Finder" or "Transducer" , lots of good info on repairing the issue.
    Old 06-23-2014, 01:05 PM   #3
    Send Txtruckerpaul:
    Ok, thanks!
    Old 06-23-2014, 09:20 PM   #4
    roger rowley is currently offline
    My Model: 238 shabah cuddy
    My Engine: 5.7gsi volvo penta /sx
    Send roger rowley:
    I had something similar gauge all over the shop, the fluid was low.Topped it up with anti freeze seems ok now
    Old 06-23-2014, 10:21 PM   #5
    Huh??
    gahooligan (06-24-2014)
    Old 06-23-2014, 10:30 PM   #6
    Send Txtruckerpaul:
    I was wondering the same thing, lol
    Old 06-24-2014, 01:35 PM   #7
    Send roger rowley:
    If you twist off the top half of the transducer there is a viscous liquid to dampen the electric pulse, anti freeze works fine because its just the right viscosity
    Old 07-08-2014, 11:32 AM   #8
    Send Txtruckerpaul:
    Larry,
    Could the transducer be in a different location? Only thing I have found under the engine is the bilge pump and the water inlet valve for the transom shower
    Old 07-08-2014, 12:41 PM   #9
    It's either underneath the front of the engine or its on the transom exterior. Never seen them mounted anywhere else.
    Old 07-08-2014, 01:19 PM   #10
    Mine was almost up against the transom in the bilge area on the starboard side of the boat.
    I 86'd it when I went to my Lowrance Sonar setup , as it didn't work anyway.(cut cable)
    Can you chase the cable Paul , to see where it goes?
    Engine Hour Gauge and Depth gauge J Thornton Original Mariah Talk 5 08-21-2013 01:45 AM
    Depth finder gauge Jaztwnz General Maintenance 11 05-15-2013 06:39 PM
    Depth Gauge michaeltrotta Original Mariah Talk 3 07-18-2012 07:06 PM
    Depth Finder works the first minutes then mad ebb8827 Original Mariah Talk 8 03-23-2010 03:52 PM
    Useful Info on Fariah Depth Sounder Z275 Original Mariah Talk 11 05-28-2008 10:17 PM
    Total Members: 18,990
    Total Threads: 13,324
    There are 232 users
