Fariah depth gauge works....sometimes
Old 07-08-2014, 02:33 PM   #11
Txtruckerpaul's Avatar
My Model: Z240 talari
My Engine: 7.4 bravo III
Send Txtruckerpaul:
Default Re: Fariah depth gauge works....sometimes
I'll track the cable down from the harness and follow it down. I ordered a new gauge and transducer yesterday. Wanted a new gauge anyways since the face of mine is faded and cracked up pretty bad
  • Old 07-08-2014, 09:37 PM   #12
    Andy b's Avatar
    Andy b is currently offline
    My Model: Diablo 180
    Gallery Images: 9
    Send Andy b:
    Originally Posted by roger rowley View Post
    If you twist off the top half of the transducer there is a viscous liquid to dampen the electric pulse, anti freeze works fine because its just the right viscosity
    What you have there sir is an oil bath transducer (same as mine)
    Thank you Andy b for this useful post!
    roger rowley (07-19-2014)
    Old 07-08-2014, 10:43 PM   #13
    Send Txtruckerpaul:
    Maybe I just needed to change the oil in mine? Ha ha ha ha ha! Lol
    Old 07-09-2014, 06:16 AM   #14
    Andy b's Avatar
    Gallery Images: 9
    Send Andy b:
    When I first got my boat the locking ring that was bonded to the boats hull was leaking so I had to constantly top up the oil...
    I rebonded it down and it's been fine ever since.
    Sent from my GT-I9505 using Tapatalk
    Old 07-10-2014, 01:40 PM   #15
    Bolo913 is currently offline
    My Model: 1994 Talari Z240
    My Engine: 5.7L Bravo III
    Send Bolo913:
    Thanks guys for the info today, my depth gauge is all over the place also, and my speedo must be clogged up to. Can't wait to get to the lake and try these tips out on my '94 240z Talari,,,,,,,,,Wake on
    Old 07-10-2014, 11:59 PM   #16
    Send Txtruckerpaul:
    Got my new faria depth gauge in the mail today, so it's looking like a Saturday project since I'll be on call at work and can't go to the lake anyways. The destructions say to use silicone instead of epoxy to mount the transducer and use propylene glycol (anti freeze?) to fill the base. Sounds easy enoughImageUploadedByTapatalk1405036762.854746.jpg
    Old 07-19-2014, 07:32 PM   #17
    Send Txtruckerpaul:
    Larry,
    I chased the cable down and mine is in the same place as yours, I think. It's in an area under the motor that I can barely see and can't reach. I'm thinking would it be ok if I put it in front of the motor where it's a lot easier to access?
    Old 07-19-2014, 07:54 PM   #18
    That is where I would install it Paul.
    Just make sure the cable is away from the pulleys/belts , and I'd say go for it.
    Make sure it is pointing straight down as possible.
    Old 07-19-2014, 07:57 PM   #19
    Send Txtruckerpaul:
    Good deal. I have a good open spot below the fuel pump on the very bottom. I'll put it there and see how it works tomorrow. Thanks!
    Old 07-19-2014, 08:02 PM   #20
    Engine Hour Gauge and Depth gauge J Thornton Original Mariah Talk 5 08-21-2013 01:45 AM
    Depth finder gauge Jaztwnz General Maintenance 11 05-15-2013 06:39 PM
    Depth Gauge michaeltrotta Original Mariah Talk 3 07-18-2012 07:06 PM
    Depth Finder works the first minutes then mad ebb8827 Original Mariah Talk 8 03-23-2010 03:52 PM
    Useful Info on Fariah Depth Sounder Z275 Original Mariah Talk 11 05-28-2008 10:17 PM
    Total Members: 18,991
    Total Threads: 13,324
    There are 253 users
