Depth finder gauge
General Maintenance
Old 05-02-2013, 01:56 PM   #1
Jaztwnz's Avatar
Jaztwnz is currently offline
My Model: 244 jubilee
My Engine: 5.7mercruiserBravo III
Gallery Images: 9
Send Jaztwnz:
Question Depth finder gauge
Mourning everyone, how do I use the depth finder? As well as post pics of my jubilee?
  • Old 05-02-2013, 03:38 PM   #2
    Andy b's Avatar
    Andy b is currently offline
    My Model: Diablo 180
    Gallery Images: 9
    Send Andy b:
    Default Re: Depth finder gauge
    which one do you have? if it's the faria I have a manual in pdf format
    Old 05-02-2013, 03:52 PM   #3
    As a Platinum contributor you should have access to all of the manuals in the 'Manuals and Supplements' section. Just as a word of warning though....if the unit starts beeping at you, you might not wanna go any further forward.
    Jaztwnz (05-02-2013)
    Old 05-02-2013, 04:00 PM   #4
    Andy b's Avatar
    Gallery Images: 9
    Send Andy b:
    Mine used to beep all the time till I found out it needed oil....
    Mind you the shallow water alarm only goes down to 2m which is a bit of a PITA
    Thank you Andy b for this useful post!
    Old 05-02-2013, 07:14 PM   #5
    Dozer's Avatar
    Dozer is currently offline
    My Model: Z202 shabah
    My Engine: 5.0 liter alpha 1
    Send Dozer:
    Default Depth finder gauge
    I have the Faria andy b if I could get a copy!! Can't figure the thing out. Why it works sometimes and not others. How to set the alarms, etc.
    Old 05-02-2013, 08:16 PM   #6
    Chances are the transducer has come loose from the epoxy mounting. This is a common problem. You can do a search on here and figure out how to remount it, but it is in somewhat of an awkward position to work on. I found sometimes just putting a little bit of water in the bilge made the depth finder work. That's the problem with in-hull depth finders, the epoxy eventually goes bad and causes these type of things.
    We have all the manuals and everything you'd ever need available, just click the "Donate" tab and find out more...
    Old 05-02-2013, 09:18 PM   #7
    Andy b's Avatar
    Gallery Images: 9
    Send Andy b:
    Unless like me you have an oil bath transducer.
    easy way to tell is if the transducer is bonded to the hull,
    or if it's fitted into a twist ring that's bonded to the hull.
    As for the manual, Mikey is right (He usually is ) there's one in the manuals section of this site
    Old 05-02-2013, 10:40 PM   #8
    now if i could only get my wife to believe that....
    Old 05-02-2013, 11:34 PM   #9
    Jaztwnz's Avatar
    Gallery Images: 9
    Send Jaztwnz:
    The manuals have come in extremely handy thanks for the advice.. I posted some pics in the gallery of my 244 jubilee.
    Old 05-15-2013, 02:39 PM   #10
    Dan_Talari 225's Avatar
    Dan_Talari 225 is currently offline
    My Model: 225 Talari
    My Engine: 5.7L Bravo I
    Send Dan_Talari 225:
    Hey gents, I am as of 5-13-13 a new Mariah owner, its a 1996 Talari 225 (it has Z 225 decals on the boat but I am unsure if it is actually a Z, but that's for another thread lol). My question is, my factory depth gauge is reading 0 at all times, does anyone know where the factory transducer is mounted and or what kind of transducer it is? Any known common problems that I might try to troubleshoot first? Any input would be greatly appreciated!
    Anybody having trouble with their OE depth finder? Purple_Shabah Original Mariah Talk 28 06-29-2016 01:51 PM
    Depth Finder issues gly101 General Maintenance 1 06-10-2012 02:57 AM
    Depth Finder jchestnutt Introductions 1 05-06-2012 12:16 AM
    Depth Finder Problem?? hatran Introductions 2 05-20-2010 06:18 PM
    Depth finder joeboat Original Mariah Talk 1 08-21-2009 12:54 AM
    There are 258 users
