Digital Fuel Gauge
Old 04-12-2014, 10:46 PM   #1
jsewall82's Avatar
jsewall82 is currently offline
My Model: z210
My Engine: 5.7L
Gallery Images: 17
Send jsewall82:
Default Digital Fuel Gauge
Has anyone replaced the analog fuel gauge with a digital one? I have been surprised several times by the sudden drop in the gauge to empty from 1/4 tank. Granted I have always been on the return trip and close to the dock but still drives me crazy.
  • Old 04-13-2014, 03:23 AM   #2
    Default Re: Digital Fuel Gauge
    More than likely not the gauge , but the sending unit.
    A lot easier to replace the sending unit , than replace the whole unit.
    Did you look at the fuel gauge fix in the "How To" section , common problem with easy fix.
    I ain't real sure I'd trust a digital gauge anyway , but that's just me
    JMO
    Old 04-13-2014, 10:04 AM   #3
    Andy b's Avatar
    Andy b is currently offline
    My Model: Diablo 180
    Gallery Images: 9
    Send Andy b:
    Fuel flow sender is the only sure way to know what you've burned.
    As long as you know how much you have to start with, you'll know how much is left
    I always fill my tank before heading out and each time my readings have been within a couple of litres (UK Boater )
    Never trusted the old wobble metter
    Old 04-13-2014, 03:33 PM   #4
    I replaced the sending unit in a few different boats. I've used the floating arm type and the float on the pole type. If I were to put a new one in my boat I would be using one of these: http://www.wemausa.com
    No particular reason other than the fact they appear to be the better built products I have personally uses and they are made in USA. Maybe I'm just biased!
    removing fuel gauge? lumbercitybravest Original Mariah Talk 1 06-30-2013 09:48 PM
    fuel gauge not working right Hoseman Original Mariah Talk 1 05-18-2010 02:32 AM
    Fuel Gauge Removal? spinks99 Projects 2 04-16-2010 02:22 AM
    Fuel gauge not working kingtide Original Mariah Talk 5 07-26-2008 06:34 PM
    There are 204 users
