how often do you guys grease the engine coupler?
Old 04-11-2014, 12:46 AM   #1
Txtruckerpaul's Avatar
My Model: Z240 talari
My Engine: 7.4 bravo III
Send Txtruckerpaul:
Default how often do you guys grease the engine coupler?
Was looking for info on the engine coupler and how often it needs to be greased. Some say every 50 hours and some others say that they just grease the splined driveshaft up real good whenever they pull the drive unit off. Mine has two grease zirks, as I was able to see when I was replacing the gimbal bearing a few weeks back. How do you even reach the grease zirks from inside the boat? I dont think I could reach back there far enough to get to them. The wife is pretty small, so maybe she could, lol. Is this something that needs to be done regularly or does greasing up the driveshaft before installing it do the same thing?
  • Old 04-11-2014, 01:15 PM   #2
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Default Re: how often do you guys grease the engine coupler?
    I just grease the splines each time I remove the outdrive, every few years. Never had a problem.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 04-11-2014, 01:44 PM   #3
    Send Txtruckerpaul:
    Ok, thanks Steve!
    Old 04-11-2014, 02:33 PM   #4
    Grease mine every year with winterization.
    Just a couple of shots
    Run probably only 50 hrs max a year these days.
    A ounce of prevention..............
    Old 04-11-2014, 02:37 PM   #5
    Send Txtruckerpaul:
    I had read to do it every 50 hrs, maybe I better talk the wife into getting back in there once a year. I certainly can't fit back there. Talari is a big boat, but it's really cramped up tight with a 7.4 back there
    Old 04-11-2014, 02:45 PM   #6
    Might think about a extension paul.
    Bet ya could rig something up if need be.
    1/8" NFPT if I remember right.
    Old 04-11-2014, 05:32 PM   #7
    gahooligan's Avatar
    My Model: 202
    My Engine: 5.7l
    Send gahooligan:
    Where is this fitting? Because the only ones I have greased are the ones on the outside of the hull on the outdrive...
    Old 04-11-2014, 06:18 PM   #8
    I give mine a couple of squirts in the fall when i winterize and its been fine in the 6 yrs i've owned my boat.
    Old 04-11-2014, 06:23 PM   #9
    My Model: Z280
    Grease fittings are located on the rearward face of the engine coupler and are 90 degree fittings which point port and starboard. Attached is a picture I found online of a blown coupler, you can see the two fittings.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 04-11-2014, 07:01 PM   #10
    Send Txtruckerpaul:
    Matt, it's between the engine and the gimbal bearing. I could see mine when I had the outdrive pulled off and could see the two grease fittings, too. It looked just like the pic that Steve posted
    Friction grease wayne344 Original Mariah Talk 1 08-24-2012 05:14 PM
    Hey Guys cpayne41 Original Mariah Talk 4 08-02-2010 03:17 AM
    Help with the speedo guys embasun Original Mariah Talk 2 01-31-2010 07:46 AM
    Maybe a engine hub/coupler Teal2000Z Mercury MerCruiser 10 09-16-2008 10:15 AM
    Guys, I need your help 93 20ft 5.0V8 mmccln7 Original Mariah Talk 3 02-24-2008 01:04 PM
    There are 314 users
