Fuel gauge not working
Old 06-20-2008, 08:05 PM   #1
kingtide is currently offline
My Model: 1996 Z240 Talari 7.4L Bravo III
Send kingtide:
Default Fuel gauge not working
My fuel gauge quit working last summer. It always shows that I have half a tank no matter if I just filled it up or almost empty. How can I fix this problem?
  • Old 06-22-2008, 12:28 PM   #2
    I'd start by checking the wiring to the gauge itself. Make sure contacts aren't corroded. Then I'd check the actual fuel sender unit, which is located on the top of the gas tank.
    Old 06-23-2008, 11:57 AM   #3
    dharby is currently offline
    My Model: 1994 Z220 Talari 350 Mag
    Send dharby:
    This year my gauge shows half a tank when full now..?? but still works somewhat (I see it bouncing around on the water and it is below half tank after a day or two of use). I won't run out, but I don't like carrying 60 gallons around (I used to carry between 15-35).
    Anyone know of any calibration or had any similar problem? I guess I will inspect connections.....maybe even add the device i read about in another thread that stops the jittery gauge.
    1994 Talari z220 350 magnum
    Old 06-25-2008, 03:50 PM   #4
    indykoch's Avatar
    indykoch is currently offline
    Send indykoch:
    Sounds like maybe the float is stuck or fuel logged. My sending unit went out last year but it always showed empty, not half full. But I guess that could still be another item to check.
    I bought a universal sending unit from West Marine and modified with some of the old pieces. It was difficult to fine tune it to the tank, but I think I have it perfect now.
    Ryan
    Previously - '99 Z212 Shabah
    350 Mag MPI
    Old 06-25-2008, 08:40 PM   #5
    Mark's Avatar
    Mark is currently offline
    My Model: 182 shabah
    My Engine: 4.3L
    Send Mark:
    As of today mine is stuck at 1/4 tank. I will look into mine on my next trip out to the boat. I hope it is just a wire. What can you do you want to play you have to pay.
    Old 07-26-2008, 06:34 PM   #6
    azboatman's Avatar
    azboatman is currently offline
    My Model: 1999 Shabah 182, Mercruiser 4.3L, Alpha One
    Gallery Images: 3
    Send azboatman:
    Hey Mark.........did you ever install the capacitor for your fuel gage? Mine is jittery, so I purchased the 68,000 capacitor. If you installed one, how did you access the fuel gage. We have the same boat, so I wanted to see if you have any suggestions.
    Thx
    AzBoatman
    Dash Gauge Lights Out Roger Butterfield General Maintenance 20 01-12-2009 08:38 PM
    Air/Water Temp Guage Not Working MAJIC Original Mariah Talk 0 06-02-2008 01:02 AM
    rev counter not working craig Original Mariah Talk 3 05-13-2008 12:31 PM
    Front Speakers not working... Z272 Original Mariah Talk 4 05-05-2008 05:57 PM
    There are 311 users
