Tilt/Trim
Old 08-27-2013, 05:53 PM   #21
Default Re: Tilt/Trim
You need to use the serial number from the drive to find the right one , it sounds like to me.
  • Old 08-27-2013, 11:12 PM   #22
    jsewall82's Avatar
    jsewall82 is currently offline
    My Model: z210
    My Engine: 5.7L
    Gallery Images: 17
    Send jsewall82:
    Looking at my drive serial number, 0F692395, it looks like this is the right one.
    865380A13 - PUMP/MOTOR ASSEMBLY, Trim (12 Volt) $700.99
    Old 08-27-2013, 11:30 PM   #23
    That is the part # I come up with too j.
    I think I'd try to find a used one that has a warranty.
    Old 08-27-2013, 11:32 PM   #24
    Here you go!
    Old 08-27-2013, 11:43 PM   #25
    jsewall82's Avatar
    My Model: z210
    My Engine: 5.7L
    Gallery Images: 17
    Send jsewall82:
    Thank you. that is awesome
    Old 08-28-2013, 12:02 AM   #26
    Yeah , I'd snag that one in a hurry!
    I've had good luck buying from DR.
    Old 08-29-2013, 05:45 PM   #27
    jsewall82's Avatar
    My Model: z210
    My Engine: 5.7L
    Gallery Images: 17
    Send jsewall82:
    Default Tilt/Trim
    I just ordered it and they are over nighting it to me. What kinda fluid does it use? That way I can have everything ready once the part arrives.
    Old 08-29-2013, 08:11 PM   #28
    Mercruiser tilt/trim fluid or 10w-30 motor oil.
    Old 08-30-2013, 02:47 PM   #29
    jsewall82's Avatar
    My Model: z210
    My Engine: 5.7L
    Gallery Images: 17
    Send jsewall82:
    Default Tilt/Trim
    How much fluid? I'm gonna drain n remove as much old as I can.
    Old 08-30-2013, 03:48 PM   #30
    Use at least 3 qts to flush the system.
    Do a search , there is various ways members are doing the process.
    Take a look here for a little more info.
    Tilt/trim eyesore. OFD4546 General Maintenance 6 01-23-2014 12:31 PM
    Trouble Shooting your Power Trim & Tilt Motor System mikeyt General Maintenance 0 07-03-2012 10:58 PM
    Trim/Tilt not working Shabah203 Original Mariah Talk 3 03-21-2012 07:06 PM
    Draining tilt,trim,fluid reservoir Douglas Alderman Mercury MerCruiser 20 05-07-2010 05:22 PM
    transom Tilt and Trim switch dwmax Original Mariah Talk 4 08-31-2009 08:10 PM
    There are 298 users
