Tilt/Trim
Old 07-09-2013, 03:34 PM   #11
Default Re: Tilt/Trim
Originally Posted by jsewall82 View Post
I plan on doing a little more research this weekend on the unit but I know I need the switch in the shifter unit replaced.
Your call but if it was me i wouldn't replace anything until i went thru the troubleshoot procedure. More often than not, there is nothing wrong with the switch (unless its been physically broken) and its usually a wet/corroded connection at one of the two solenoids or pump that causes the problem.
  • Old 07-09-2013, 03:42 PM   #12
    jsewall82's Avatar
    jsewall82 is currently offline
    My Model: z210
    My Engine: 5.7L
    Gallery Images: 17
    Send jsewall82:
    the switch sticks in the up or down position. it doesn't "bounce" back like it should.
    Old 08-24-2013, 10:37 PM   #13
    jsewall82's Avatar
    My Model: z210
    My Engine: 5.7L
    Gallery Images: 17
    Send jsewall82:
    Default Tilt/Trim
    So I diagnosed the trim/tilt issue. It seems that the trim pump is not working. My uncle, a master electrician and shade tree mechanic, came over and even with the lift cylinder unhooked we could not get any of the hydraulic fluid out. All the electrical is good and is testing the way it should. What's a good place to get a new unit?
    Old 08-25-2013, 03:40 AM   #14
    You have a Alpha or a Bravo Drive?
    Looks like either way , part # is 865380A13.
    Merc price is around 700.00. OUCH!
    Look on Ebay.
    Might try part # 14336A8
    Or get a used one.
    Old 08-25-2013, 03:43 PM   #15
    jsewall82's Avatar
    My Model: z210
    My Engine: 5.7L
    Gallery Images: 17
    Send jsewall82:
    Default Tilt/Trim
    Alpha one gen ii. I found one for like $300 but I didn't have part # on me to verify
    Old 08-25-2013, 04:08 PM   #16
    jsewall82's Avatar
    My Model: z210
    My Engine: 5.7L
    Gallery Images: 17
    Send jsewall82:
    Default Tilt/Trim
    Looks like its not the right one. I will have to do some research. The one I found for like $700 is saying I have to buy adapters for the hydraulic lines because the one I'm replacing is a 1996.
    Old 08-26-2013, 04:19 PM   #17
    lumbercitybravest's Avatar
    lumbercitybravest is currently offline
    My Model: 225 davanti
    My Engine: 5.0l alpha
    Gallery Images: 4
    Send lumbercitybravest:
    Where are you located? A good auto electric place should be able to rebuild those motors....my neighbor had his rebuilt like new for just a shade over $100
    Old 08-26-2013, 08:27 PM   #18
    jsewall82's Avatar
    My Model: z210
    My Engine: 5.7L
    Gallery Images: 17
    Send jsewall82:
    Default Tilt/Trim
    Senoia, ga. Home of the walking dead.
    Hrdcor likes this.
    Old 08-27-2013, 04:44 PM   #19
    jsewall82's Avatar
    My Model: z210
    My Engine: 5.7L
    Gallery Images: 17
    Send jsewall82:
    Default Tilt/Trim
    Can anyone tell me if this is the right part?
    http://www.iboats.com/Mercury-Marine-Mercruiser-Inboard-OEM-Replacement-Power-Tilt-and-Trim-Motor-6275-Complete-Arco/dm/cart_id.277230033--session_id.310367865--view_id.351013
    Old 08-27-2013, 05:35 PM   #20
    jsewall82's Avatar
    My Model: z210
    My Engine: 5.7L
    Gallery Images: 17
    Send jsewall82:
    Default Tilt/Trim
    Or is this right?
    http://www.amazon.com/gp/aw/d/B00AN8T064/ref=mp_s_a_1_fkmr0_1?qid=1377624904&sr=8-1-fkmr0&pi=SL75
    Tilt/trim eyesore. OFD4546 General Maintenance 6 01-23-2014 12:31 PM
    Trouble Shooting your Power Trim & Tilt Motor System mikeyt General Maintenance 0 07-03-2012 10:58 PM
    Trim/Tilt not working Shabah203 Original Mariah Talk 3 03-21-2012 07:06 PM
    Draining tilt,trim,fluid reservoir Douglas Alderman Mercury MerCruiser 20 05-07-2010 05:22 PM
    transom Tilt and Trim switch dwmax Original Mariah Talk 4 08-31-2009 08:10 PM
    There are 438 users
