porpoising z210
Old 06-08-2013, 01:48 PM   #31
rhinoz is currently offline
Send rhinoz:
Default Re: porpoising z210
Originally Posted by nglauer View Post
Hope I don't insult anyone.. but as a reminder
Measure ten times, not twice... this is a Mariah!!!..... you may need a small thing of tissues - cause drilling her may make you cry or have cold sweats.
If you have a Whale Tail - quietly remove it before posting "before photo's" to the forum.. or moving onto the next step. Also, you don't want to be "that guy"... the one responsible for giving MikeyT a stroke, high blood pressure, or any other number of debilitating boat picture induced coma's.
Mask the area to be drilled to help stop any spidering of the gelcoat. - also, it's sort of like blind folding your boat so she doesn't know whats about to happen until it's already over.
Reverse your drill and run it slowly allowing the backside of the bit to burn through the exterior gelcoat - then turn the drill the right direction to drill the actual hole (if that made sense lol). Run both directions at a mild pace and check the shavings for moisture etc. (one of my holes actually had water run out... this may be normal but I panicked immediately )
Have some 3M marine adhesive handy (just don't buy a semi expired tube of it like i did - It wouldn't come out with my gun, so I had to slice the side of it and dip it out.. man was that messy.. but it worked and was only $2.00 for a big tube of 4200 and 5200)
Have a pair of pliers, a flat screw driver, a small handsaw, a utility knife, and some stainless staples and a stapler handy in case you have to go all Dexter and cut back any of the bunks on your trailer. (I had to cut two of my bunks so they were flush with the transom - if not they may have interfered with the Smart Tab's when loading/unloading).
Also, have a cooler with your favorite beverage on standbye - not because the installation will take long... but because you'll want to have a cold one while you admire your handy work.. and possibly one of the single best mods you'll ever do to your beloved Mariah!
Thanks (sarcasm)..there I was all prepared with tools at the ready, now I'm reaching for some jumbo towels to wipe the sweat off. I think I need another coffee LOL...I'll post my results a pic of my handiwork later on my first attempt to breach the hull
1996 Mariah Shabah 180 (Ms. Whiplash)
  • Old 06-08-2013, 02:15 PM   #32
    nglauer's Avatar
    nglauer is currently offline
    My Model: 180 Diablo
    My Engine: 3.0L Alpha one
    Send nglauer:
    LOL... it'll be okay.. once you poke her once, you'll be okay with poking her a few more times lol
    Old 06-08-2013, 02:31 PM   #33
    Send rhinoz:
    Not even gonna go there with an answer to that, I'd get banned from here LOL
    Old 06-08-2013, 02:34 PM   #34
    nglauer's Avatar
    Send nglauer:
    True... well... we will let you get back to screwing bwahaha. But seriously.. use that tape for protection :O
    1996 z210 jsewall82 Original Mariah Talk 7 04-18-2013 03:10 PM
    Wanted: WTB: '99-'01 Z210 Shabah mariahboy Mariah Parts For Sale & Wanted 5 03-20-2013 04:34 PM
    What does this Z210 switch do? scboater Original Mariah Talk 10 07-30-2012 02:16 AM
    differences-z210 vs 212 rusty Original Mariah Talk 5 05-28-2009 01:24 PM
    1997 Shabah Z210 Captain Steve Introductions 4 09-23-2007 06:22 PM
    There are 309 users
