porpoising z210
Anybody with a z210 have an issue with porpoising? Took the boat out on sat and couldn't get it to stop. Didnt matter where people sat or trim, it would still do it. It was windy out but didnt seem to bother other boats on the water.
Re: porpoising z210
Are you sure that your outdrive is actually trimming properly?
If it is then you may have to do what most others do who have this problem. Install a set of Smart Tabs. |
porpoising z210
It was trimming correctly. Even had the other half operate it while I watched it.
Re: porpoising z210
Read somewhere that someone had a "whalefin" on the outdrive and it was loose causing the up and down motion, wasn't loose by much but enough where trim wasn't making that much difference to counteract it but got the porpoise effect at any speed...shot in the dark I guess
porpoising z210
No fin on the out drive. Guess ill look into the tabs
porpoising z210
Tabs are well worth the money, added them over the winter months and have been enjoying them the last 10 or so trips out. Great investments. And they look cool when plained out!
Re: porpoising z210
porpoising z210
I have seen the tutorial on the tabs on here. What kind/size would be a good start? I'm away at a conference with the army so have limited Internet to research. Would like to order them ASAP.
Re: porpoising z210
Re: porpoising z210
| All times are GMT. The time now is 09:39 AM. |
