porpoising z210
Old 06-07-2013, 02:43 AM   #21
Default Re: porpoising z210
Originally Posted by Andy b View Post
Bit of a pet peeve aye Mikey
Definitely.... those things are good for tin cans with outboards on the tail and that's it.
  • Old 06-07-2013, 03:02 AM   #22
    nglauer's Avatar
    nglauer is currently offline
    My Model: 180 Diablo
    My Engine: 3.0L Alpha one
    Send nglauer:
    I don't think this Tin can has a whale tail...
    Old 06-07-2013, 03:04 AM   #23
    Doesn't have an outboard either....
    Old 06-07-2013, 03:04 AM   #24
    I gotta see it even float!!
    Old 06-07-2013, 05:32 PM   #25
    nglauer's Avatar
    Send nglauer:
    It has lot's of thing's mounted "outboard" lol. I would have loved to of seen this in the water!!!!
    Old 06-07-2013, 06:54 PM   #26
    rhinoz is currently offline
    Send rhinoz:
    Got my trim tabs today, they're going on the boat tonight as soon as I get out of work and then off to the lake late tomorrow with no porpoise effect
    1996 Mariah Shabah 180 (Ms. Whiplash)
    Old 06-07-2013, 06:58 PM   #27
    jsewall82's Avatar
    jsewall82 is currently offline
    My Model: z210
    My Engine: 5.7L
    Gallery Images: 17
    Send jsewall82:
    i ordered mine yesterday. not sure when I will get them, hope its before I head down to the Suwanee river
    Old 06-07-2013, 07:48 PM   #28
    Way down upon de Swanee Ribber,
    Far, far away,
    Dere's wha my heart is turning ebber,
    Dere's where de old folks play.
    oops sorry 'bout that.
    Andy b likes this.
    Old 06-07-2013, 07:51 PM   #29
    jsewall82's Avatar
    My Model: z210
    My Engine: 5.7L
    Gallery Images: 17
    Send jsewall82:
    Default porpoising z210
    Ha ha. Family has property on it so its free place stay right on the water.
    Old 06-07-2013, 07:59 PM   #30
    nglauer's Avatar
    Send nglauer:
    Hope I don't insult anyone.. but as a reminder
    Measure ten times, not twice... this is a Mariah!!!..... you may need a small thing of tissues - cause drilling her may make you cry or have cold sweats.
    If you have a Whale Tail - quietly remove it before posting "before photo's" to the forum.. or moving onto the next step. Also, you don't want to be "that guy"... the one responsible for giving MikeyT a stroke, high blood pressure, or any other number of debilitating boat picture induced coma's.
    Mask the area to be drilled to help stop any spidering of the gelcoat. - also, it's sort of like blind folding your boat so she doesn't know whats about to happen until it's already over.
    Reverse your drill and run it slowly allowing the backside of the bit to burn through the exterior gelcoat - then turn the drill the right direction to drill the actual hole (if that made sense lol). Run both directions at a mild pace and check the shavings for moisture etc. (one of my holes actually had water run out... this may be normal but I panicked immediately )
    Have some 3M marine adhesive handy (just don't buy a semi expired tube of it like i did - It wouldn't come out with my gun, so I had to slice the side of it and dip it out.. man was that messy.. but it worked and was only $2.00 for a big tube of 4200 and 5200)
    Have a pair of pliers, a flat screw driver, a small handsaw, a utility knife, and some stainless staples and a stapler handy in case you have to go all Dexter and cut back any of the bunks on your trailer. (I had to cut two of my bunks so they were flush with the transom - if not they may have interfered with the Smart Tab's when loading/unloading).
    Also, have a cooler with your favorite beverage on standbye - not because the installation will take long... but because you'll want to have a cold one while you admire your handy work.. and possibly one of the single best mods you'll ever do to your beloved Mariah!
    rhinoz likes this.
    1996 z210 jsewall82 Original Mariah Talk 7 04-18-2013 03:10 PM
    Wanted: WTB: '99-'01 Z210 Shabah mariahboy Mariah Parts For Sale & Wanted 5 03-20-2013 04:34 PM
    What does this Z210 switch do? scboater Original Mariah Talk 10 07-30-2012 02:16 AM
    differences-z210 vs 212 rusty Original Mariah Talk 5 05-28-2009 01:24 PM
    1997 Shabah Z210 Captain Steve Introductions 4 09-23-2007 06:22 PM
    There are 311 users
