porpoising z210
Old 06-05-2013, 04:36 PM   #11
Andy b's Avatar
Andy b is currently offline
My Model: Diablo 180
Gallery Images: 9
Send Andy b:
Default Re: porpoising z210
Anyone who installed a whale tail on their Mariah outdrive deserves to have it porpoise.
Oh dear! there goes Mikey's blood pressure again!
Bit of a pet peeve aye Mikey
nglauer likes this.
  • Old 06-05-2013, 05:01 PM   #12
    I agree with him wholeheartedly!!
    Andy b and rhinoz like this.
    Old 06-05-2013, 07:27 PM   #13
    Originally Posted by rhinoz View Post
    #80's Nauticus Trim Tabs Sx Composite 9.5"X10"-80*, says $129.99 but when you add them to the cart it drops to $99.99...I ordered a set of 60's for myself this morning
    I think that you will find the 80 lb arms too stiff for your 180. Most of the rest of us did...
    Old 06-05-2013, 07:58 PM   #14
    Andy b's Avatar
    Gallery Images: 9
    Send Andy b:
    My 60's run on the middle holes,
    unless I know it's gona be a bit rough or I have a boat full.
    On their hardest setting they have there own roosters so they must still be digging in
    And I loose a good 5 or more MPH off my top end if I forget to reset them!
    I know you won't need 80's on a 180
    Old 06-05-2013, 11:04 PM   #15
    voodoo's Avatar
    voodoo is currently offline
    My Model: Davanti
    My Engine: 5.7
    Send voodoo:
    I had a 16 footer that I swear had a ground up porpoise glassed into the hull.
    My thumb got tired from constant trimming with limited results.
    Smart tabs did all they claimed and better.
    Company support during purchase and install was first rate.
    Can't praise them enough.
    Old 06-06-2013, 03:16 AM   #16
    nglauer's Avatar
    nglauer is currently offline
    My Model: 180 Diablo
    My Engine: 3.0L Alpha one
    Send nglauer:
    I have the 60's on my Diablo 180 with the 3.0L. I can't remember how I have mine set - but they put the boat up on plane instantly without nailing the throttle. I absolutely love them.. but the best part is when i'm heading back to the boat ramp (which is a long stretch of no wake area where you have to "creep" FOREVER. The Smart tabs made me go from looking like a drunk driver (had to constantly work the wheel left to right to stay semi straight).. to a perfect driver. The boat tracks perfectly straight at super low speeds now. Also, I did not lose any MPH with my install (checked it before and after running my 14.5x17p Michigan 3 blade on my GPS). However, I will test it out again..once I swap over to my 19p (which I need to get rebuilt).
    Old 06-06-2013, 12:33 PM   #17
    jsewall82's Avatar
    jsewall82 is currently offline
    My Model: z210
    My Engine: 5.7L
    Gallery Images: 17
    Send jsewall82:
    Just so I get this right before I order them, I need the 80# ones for my z210 correct?
    Old 06-06-2013, 02:32 PM   #18
    Andy b's Avatar
    Gallery Images: 9
    Send Andy b:
    I don't notice any loss with them set on the middle hole. it's just if I've got them set on the hardest setting (furthest hole out) they dig in and slow the boat.....a bit
    mind you if I've got them set hard then i'm either loaded or it's choppy out so i'm gona be slower anyway
    Old 06-06-2013, 03:08 PM   #19
    jsewall82,
    Yes the 80lb tabs are what your after.
    You have 5 different settings to play with for downforce adjustment.
    Old 06-07-2013, 02:31 AM   #20
    jarwiebe's Avatar
    jarwiebe is currently offline
    My Model: Z210 Shabah
    My Engine: 5.7 LX Alpha I
    Gallery Images: 2
    Send jarwiebe:
    Originally Posted by jsewall82 View Post
    Anybody with a z210 have an issue with porpoising? Took the boat out on sat and couldn't get it to stop. Didnt matter where people sat or trim, it would still do it. It was windy out but didnt seem to bother other boats on the water.
    I had the 80 lb tabs installed on my Z210 before I took it out for the first time and can't compare the with/without tabs, but I can say that I have never had it porpoising in the 60 hours that I've put on the clock. I usually run with them on the middle setting.
    Cheers
    Jake
    1996 Z210 Shabah
    Mercruiser 5.7LX
    Alpha One Drive
    80 Lb. SX Smart Tabs
    1996 z210 jsewall82 Original Mariah Talk 7 04-18-2013 03:10 PM
    Wanted: WTB: '99-'01 Z210 Shabah mariahboy Mariah Parts For Sale & Wanted 5 03-20-2013 04:34 PM
    What does this Z210 switch do? scboater Original Mariah Talk 10 07-30-2012 02:16 AM
    differences-z210 vs 212 rusty Original Mariah Talk 5 05-28-2009 01:24 PM
    1997 Shabah Z210 Captain Steve Introductions 4 09-23-2007 06:22 PM
    There are 217 users
