Mariah 180 throttle control not returning to neutral
Old 10-06-2011, 11:26 AM   #1
ol1000 is currently offline
My Model: 182
My Engine: 4.3 Volvo
Send ol1000:
Default Mariah 180 throttle control not returning to neutral
Hi All,
New to the Mariah family. I have just got a 2001 Mariah 180 with a volvo 4.3 V6.
The throttle control level is a little stiff but more importantly it has a lot of trouble returning to neutral. If you just slowly return the level to the neutral from forward it will jam and not go. You have to jiggle / waggle it until it pops back to neutral...
Any thoughts / advice much appreciated
Also I cannot search this forum, everything I search for, even as simple as 180 just returns no results... any ideas here as well??
Thanks in advance
  • Old 10-06-2011, 09:28 PM   #2
    DougR is currently offline
    My Year: 2003
    My Model: SX 20
    My Engine: 5.7
    Send DougR:
    Default Re: Mariah 180 throttle control not returning to neutral
    Do you know what model of control you have? Seems to be a lot of problems with the older 3000 series (speaking of experience). How do the cables look?
    -Doug
    Old 10-07-2011, 02:46 PM   #3
    Dredd's Avatar
    Dredd is currently offline
    My Model: MX-19 - Sold
    Send Dredd:
    Thanks in advance
    Try adding more to your search criteria. I don't know why it's just saying no results but on most boards if your criteria is to vague then they don't even attempt to run the search.
    I tried, 180 and got what you got.
    Then, I tried bimini top frame and got results.
    Old 10-19-2011, 10:50 AM   #4
    My Model: 182
    Send ol1000:
    Thanks Dude. will give it a go
    Old 10-19-2011, 01:34 PM   #5
    DFZ272 is currently offline
    My Model: Z272 Barchetta
    My Engine: 7.4 Bravo III
    Send DFZ272:
    Does it only bind when running or when then engine is off, or both? With the engine off you might try disconnecting the engine end of the control cables then moving your shifter to see if it is binding. That would be an easy check. If it is stiff, then u will know that the problem is the cables or throttle quadrant. If they move freely then u need to check the next area down the line. Has anything been worked on recently? Any grinding or strange noises when moving the shifter? Just trying to get some more information so forum members can help.
    Happy Boating
    Dan
    1995 Z272 Barchetta
    Throttle Control - Mercury recall bdbyrnes Original Mariah Talk 2 09-02-2011 08:39 PM
    Has anyone taken apart their throttle control to fix trim switch? csterner Mercury MerCruiser 7 08-30-2011 06:41 PM
    Vibration in neutral yblockmike Mercury MerCruiser 1 03-31-2011 05:02 PM
    sticky neutral button on volvo penta tagsfirst Original Mariah Talk 4 08-21-2010 06:44 AM
    Throttle Control Shifter Question? Douglas Alderman Original Mariah Talk 21 06-25-2009 07:44 PM
    There are 249 users
