Throttle Control Shifter Question?
Old 04-19-2008, 12:33 AM   #1
Gallery Images: 2
Send Douglas Alderman:
Default Throttle Control Shifter Question?
I have a single handle shifter with trim and tilt controls. Question!! Does the trailer switch on the handle have a stop engine setting? My motor would not keep running while trying to start engine. Flipped switch and motor started. Looked it up in boat manual and couldn't find anything about it.
  • Old 04-19-2008, 02:30 AM   #2
    jmills224's Avatar
    jmills224 is currently offline
    My Model: 1997 179SE Talari 4.3LX Gen+/Alpha1 Gen II
    Gallery Images: 4
    Send jmills224:
    Doug,
    That switch you flipped is probably the kill switch. Normally a clip goes in it with a lanyard attached to it. The lanyard then would clip to your body. The purpose of the switch/lanyard is to kill the engine if you were to be thrown from the boat.
    HTH
    ~J
    Old 04-19-2008, 01:01 PM   #3
    180diablo's Avatar
    My Model: 1993 Diablo 180
    Gallery Images: 30
    Send 180diablo:
    "flipped the switch"..? .... In reference to my boat, the trailer switch is a square button pad above the tilt/trim that you press straight in for trailering. Unless they have changed that and updated it (haven't been in newer boats recently).
    To me, it sounded like you were trying to start the motor while the sterndrive was in the full up vs the full down position..?
    The kill switch on my boat is located on the right side of the helm area below my radio. Which as jmills mentioned, would have the lanyard.
    ~ Ryan
    Owner of the 3.0L Powerhouse!
    Old 04-19-2008, 02:36 PM   #4
    jmills224's Avatar
    Gallery Images: 4
    Send jmills224:
    I forgot mention mine is on the shifter in the lower left-hand corner.
    ~J
    Old 04-19-2008, 09:13 PM   #5
    Hi Doug,
    I'm trying to figure out what you meant, but it sounds like you said your trailer switch is a lever... and after flipping the "lever" the motor ran. If this is correct it gets kind of confusing because almost all the single arm throttle/shifter units I have seen are like what jmills224 described, they have a trailer button either located on the surface plate or on the throttle arm.
    Could you tell us the brand and model throttle/shifter you have or picture would help a lot.
    Old 04-19-2008, 10:05 PM   #6
    Gallery Images: 2
    Default Throttle Shifter
    After viewing throttle shifter more closely , I could just make out the writing on the switch. Off and On. Being new to this boat I didn't know this would cause the engine not to start. Sending pictures of Throttle Shifter from my boat.
    Old 04-19-2008, 10:27 PM   #7
    Gallery Images: 2
    Default Thottle Shifter Pictures
    Throttle Shifter
    Old 04-19-2008, 10:33 PM   #8
    Gallery Images: 2
    Default Throttle switches
    Old 04-20-2008, 02:07 AM   #9
    jmills224's Avatar
    Gallery Images: 4
    Send jmills224:
    That is exactly the same shifter I have. That switch is for a clip and lanyard to attach to. If that switch is on the off position it kills the power to your ignition and the motor will not run. Wal-Mart usually has an assortment of clips and I think the proper one is in that pack. Its about $6 US and well worth it. You don't have to have it but for safety sake you should have/use it.
    ~J
    Old 04-20-2008, 03:22 AM   #10
    Hi Douglas,
    Well, it seems the Commander 3000 was a popular controller! We all have the same type, although my Trailer switch is in the lower right hand corner of the body, not on the throttle handle like yours.
    Jmills224 is absolutely right about using the lanyard, is a safety device and could save you life if you’re ever thrown from the helm.
    I’ve included several pictures of the lanyard so you know which one to get ( has a loop on the end ) and how it’s connected to the Kill Switch.
    The first is the lanyard, metal to you, black loop to the kill switch.
    Second pic is with the lanyard installed.
    Third pic is in the "Run" position (red lever up).
    Forth pic is when the lanyard pulls out (forces red lever down).
    Lastly, where our trailer switch is located in comparison to yours.
    Last edited by WetWilly; 04-20-2008 at 04:20 AM. Reason: Added picture discriptions
    Throttle Body Restriction?? Jeff Barnett Mercury MerCruiser 13 08-31-2011 02:20 PM
    Clarion Remote Control @ helm il_Mio Sea Fox - Mariah Talk 8 08-03-2008 12:45 PM
    Another thottle shifter ? 01DiabloMissouri Original Mariah Talk 4 04-25-2008 02:38 PM
    Remote control tnmc13 Original Mariah Talk 10 03-13-2008 02:40 AM
    Throttle and shifter question.. Jeff Barnett Original Mariah Talk 3 09-19-2007 12:30 AM
    There are 249 users
