Vibration in neutral
Old 03-24-2011, 12:47 AM   #1
yblockmike's Avatar
yblockmike is currently offline
My Model: shabah 202 limited
My Engine: 5.0 mercruiser
Send yblockmike:
Default Vibration in neutral
Hello all, been a while since I've visited the site. Time to start thinking about getting my 95 Barchetta ready for summer. Last year I noticed when starting the engine up, I had a really bad vibration....the higher the RPM's the worse it would get. Not that noticable at idle, and did not notice any vibration once the outdrive was in forward or reverse. Any thoughts on what I should be looking for? gimble bearing? u-joints on the coupler? I restore classic cars and build street rods, so pretty mechanical, however new to boating, and still learning! My barchetta has the mercruiser 4.3LX Alpha set up. Its also very hard to start when cold, fires right up warm. Any suggestions on what I need to look at on that would be greatly appreciated too!
  • Old 03-31-2011, 05:02 PM   #2
    Send 300sflyer:
    Default Re: Vibration in neutral
    My first though would be u-joints and the gimbal bearing. How long has it been since the drive was removed, and they were inspected? While the drive is off, it would be a good idea to check the engine alignment as well.
    Thank you 300sflyer for this useful post!
    yblockmike (04-04-2011)
    Trailer Vibration - Only at 35mph? Slash9point5 Trailering and Tow Vehicles 5 05-13-2011 05:15 PM
    sticky neutral button on volvo penta tagsfirst Original Mariah Talk 4 08-21-2010 06:44 AM
    Vibration from Outdrive? dudders Mercury MerCruiser 10 01-13-2008 04:09 AM
    There are 336 users
