leaning issue... overpropped?
Old 06-13-2011, 02:46 PM   #1
DCB_MINDED's Avatar
My Model: Shabah 238
My Engine: 5.7 Alpha1
Send DCB_MINDED:
Default leaning issue... overpropped?
I bought a 1999 238 last week with a 5.7L Alpha. Boat is in great shape, but it's slow to plane, and lays to the left when it is on plane. I read online that the whaletail can make it do this. So, I took it off.... without the whaletail, it wont plane without a 200 lb guy getting in the bow and it bounces like crazy! it currently has a 19p 3 blade on it, and runs about 42 at WOT while turning about 4000 RPM. I know it's overpropped, and think that this may be part of my leaning issue. I'm considering buynig a highfive 17p or a revolution 4 15p. Thoughts or inputs? Any other reccomendations? Thanks in advance for the help!
  • Old 06-13-2011, 05:21 PM   #2
    Default Re: leaning issue... overpropped?
    You've suggested some good possibilities. But i would drop to a 17" prop, not a 15". The high 5 is a nice prop but seems to be a little particular on where it works best. A Stiletto is a good all around prop and i would also consider a 4 blade 17 SS prop for your boat.
    You might also want to have a close look at how well balanced things are stored within your boat. Its surprising but a difference of 100-200 lbs on each side can cause a significant lean.
    As for the 'whale tail', anyone who installs one of those things should be shot & pissed on and not necessarily in that order.
    let us know how you make out!
    Old 06-13-2011, 09:09 PM   #3
    DCB_MINDED's Avatar
    Send DCB_MINDED:
    Agreed on the whaletail... Seems to be a "band-aid" to a larger problem... Definitely wanna get rid of it. I just hate to spend 4-500 bucks without doing some testing... cant find anywhere here to borrow or rent a prop.
    Winching issue sanukc Trailering and Tow Vehicles 5 07-05-2011 09:21 PM
    Pick up issue karae225 Original Mariah Talk 1 04-13-2011 01:40 AM
    Charging issue Twkenny Mercury MerCruiser 4 04-04-2011 12:56 PM
    new member with issue 2006sx18 Introductions 9 08-13-2008 10:45 PM
    Engine issue from new bakdraft Sea Fox - Mariah Talk 6 07-13-2008 11:20 PM
    There are 362 users
