Pick up issue
Old 04-10-2011, 11:56 PM   #1
karae225 is currently offline
My Model: z225 talari
My Engine: 5.7 mercruiser
Send karae225:
Default Pick up issue
I have a '96 Talari and the pick up in the tank isn't working properly. I have replaced the fuel pump twice. The second time is with a high performance pump that works properly. We think either the pick up is bad or the tube is collapsing from the the tank to the pump. The only way, from we see, is to cut a section of the floor and/or the whole floor in order to get to the area that needs work. Is there a better soloution? Please let me know. Thanks
Mike
  • Old 04-13-2011, 01:40 AM   #2
    wplaine's Avatar
    wplaine is currently offline
    My Model: Z215 Talari
    My Engine: 5.7L Bravo III
    Gallery Images: 15
    Send wplaine:
    Default Re: Pick up issue
    Vent clear? will it pump fuel with the gas cap open to check for vapor lock/vacuum?
    Walter in VA
    '96 Talari Z215
    350 Merc/Bravo III
    Charging issue Twkenny Mercury MerCruiser 4 04-04-2011 12:56 PM
    How to pick 4 blade prop? karmann Prop Talk 2 08-05-2009 02:22 AM
    new member with issue 2006sx18 Introductions 9 08-13-2008 10:45 PM
    Engine issue from new bakdraft Sea Fox - Mariah Talk 6 07-13-2008 11:20 PM
    Went to pick up the boat... NOOOOO!!!!! indykoch Original Mariah Talk 15 05-06-2008 04:17 AM
    There are 255 users
