Faria depth gauge
Old 07-29-2010, 02:24 AM   #1
Slamsanders is currently offline
My Model: 192 shabah
My Engine: 5.0 alpha I
Send Slamsanders:
Default Faria depth gauge
Can anyone tell me how to troubleshoot the Faria depth gauge on my 2001 192 Shabah. The gauge comes on but just reads UN I guess for unknown. I looked in the engine compartment and found the transducer it seems to be hooked up fine.
  • Old 07-29-2010, 03:04 AM   #2
    Default Re: Faria depth gauge
    Check to see if the transducer has come loose in its mount. If so it wont read properly even if still wired correctly.
    Old 07-29-2010, 03:26 AM   #3
    Send Slamsanders:
    Checked that it is securely hooked to mount. Anything else I can check?
    Old 07-29-2010, 12:21 PM   #4
    I would try contacting Faria, this may be a common problem and they might have a easy fix available or it may be time to send it back for the warranty repair.
    Old 07-29-2010, 06:09 PM   #5
    Send Slamsanders:
    Ok thank you. Will give them a try.
    Old 07-30-2010, 10:24 PM   #6
    WalkinOnWater's Avatar
    WalkinOnWater is currently offline
    My Model: Z-202 Shabah Ltd
    My Engine: 5.0L EFI Alpha
    Send WalkinOnWater:
    I have the exact same problem. If I push "mode" it will go from shallowest depth, to deepest, to "UN", and that's it. I'm trying to figure it out also. If I do I'll let you know and you do the same.
    Thanks.
    2001 Z-202 Shabah
    Old 08-01-2010, 12:01 PM   #7
    Send Slamsanders:
    Ok sounds good. I have't contacted Faria yet been at the lake too much. But when I get it fixed I will post any resolution here.
    Old 08-05-2010, 11:04 AM   #8
    Send Slamsanders:
    Ok so I think I know what the problem is with my depth finder, the transducer is mounted on a ring that is about an inch tall so there is air space between the bottom of it and the boat, that air space has to be filled with mineral oil because the signal will not pass through air. Mine was dry as a bone! Hope this helps.
    Aftermarket Depth Gauge Kitto Original Mariah Talk 16 07-13-2010 02:02 PM
    Faria RPM Gauge does not "zero" MariahMan Original Mariah Talk 9 05-26-2010 11:47 AM
    Faria gauge repair issues DONNA General Maintenance 6 05-25-2010 02:02 AM
    Faria ewcjoro Original Mariah Talk 3 03-25-2009 04:06 PM
    There are 424 users
