Faria RPM Gauge does not "zero"
Old 07-19-2007, 04:11 AM   #1
MariahMan's Avatar
Status: Admin Guy
My Model: 252 Shabah
Gallery Images: 211
Send MariahMan:
Default Faria RPM Gauge does not "zero"
On my 2001 252 Shabah, the Faria RPM guage does not return to zero when i shut the boat off. Instead, the gauge simply remains at idle, approximately 600 RPM's or so. I've never tried running the boat at a higher rpm then killing it to see what the guage does as i would imagine this can't be good for the motor.
The dealer i bought the boat from, Ski-Master's in Kenmore, told me that it is normal for the gauge to remain at the last rpm before the engine was shut off. These guys screwed up a lot of things and were total morons so i stopped going to them and have since found a new service center for my boat. As a result, i'm wondering how accurate their statement that "it's normal" really is.
Any ideas? Anyone else's RPM gauge do this? It's not really a problem, just an oddity i was curious about.
-Ryan
ThunderShark Web Solutions
  • Old 07-19-2007, 11:02 AM   #2
    moondance100's Avatar
    moondance100 is currently offline
    My Model: 1995 Z240 Talari 502 Bravo III
    Send moondance100:
    Ryan, I don't think thats unusual; actually, I think my 95 does that. Is it something that just started? What does it do when you switch on the ignition?
    Have you tried getting the engine to 0 rpms before you turn it off?
    Old 07-19-2007, 11:49 AM   #3
    I had a similar problem with my gauge also. Here's a test you can do to see if it's a connection issue. When the boat's running, kind of knock the front of the gauge with your knuckle. If the tach jumps and reads another level, then here's what to do.
    They made these gauges universal for 4,6,& 8 cylinder engines. On the back of the gauge where the wiring hookup is, there's a small switch for each engine setting. You'll need a small flathead screwdriver. Insert into the switch and cycle through the different settings a few times. What happens is after a while, the contacts become dirty, and by cycling through the different settings, it "cleans" the contacts a bit.
    After I did this, I haven't had any problems with it. If this doesn't help, you might try dropping Faria a line, they're actually really helpful.
    Old 07-19-2007, 02:05 PM   #4
    indykoch's Avatar
    indykoch is currently offline
    Send indykoch:
    I had an issue where it wasn't reading accurately, Wierd Walt (on the TB forum) told me to do this exact fix as well - worked like a charm.
    If it doesn't work, Faria gauges have a lifetime warranty. Problem is, I don't know what they could do about the gold/brass surrounding and "Mariah" emblem.
    Ryan
    Previously - '99 Z212 Shabah
    350 Mag MPI
    Old 07-19-2007, 02:16 PM   #5
    180diablo's Avatar
    My Model: 1993 Diablo 180
    Gallery Images: 30
    Send 180diablo:
    When I referenced some older pics of my boat in storage last year, it shows my rpm gauge to be sitting around 100-200rpm. Don't recall if it still sits in that same location recently. I will have to take another look at it next week. I do know my trim gauge jumps all the way up to the top when the key is shut off, but as soon as the key is put into "run" position it returns to correct trim location.
    ~ Ryan
    Owner of the 3.0L Powerhouse!
    Old 07-19-2007, 04:45 PM   #6
    Faria's "Euro Gold" series is a very close match if you'd have to replace it, the numbers are a little more bold than the original though. Here's what their speedo looks like. (couldn't find a small tach image)
    You might try to give them a call and see if they might possibly have some of the OEM gauges for the Mariahs? Who knows what they've got lurking in dusty corners of the warehouse!
    Old 07-19-2007, 07:27 PM   #7
    MariahMan's Avatar
    Status: Admin Guy
    Gallery Images: 211
    Send MariahMan:
    I'll try that next time, haha.
    I'll try your test chris. Maybe that'll fix it. This issue isn't anything new so we'll see. Been like this since we've had the boat. I think i'll give Faria a call just to see what they got. Who knows, maybe i'll strike it rich and hit the jackpot and they'll have a whole ton of gauges.
    -Ryan
    Old 07-19-2007, 08:08 PM   #8
    94 Talari's Avatar
    94 Talari is currently offline
    My Model: 180 Talari
    My Engine: 4.3L LX
    Gallery Images: 2
    Send 94 Talari:
    This is very timely info!
    Since my tach just started doing this a couple of weeks ago, I'll have to try the fix. I had resorted to tapping the bezel of the gauge to "correct" it.
    Thanks, Ron.
    1994 Mariah Talari 180 4.3 LX
    Old 07-19-2007, 08:36 PM   #9
    Originally Posted by 94 Talari View Post
    This is very timely info!.
    Hey, that's exactly what we're all here for, and what this site is all about!!!
    Old 05-26-2010, 11:47 AM   #10
    Lloyd Chip Lambert is currently offline
    My Model: Z252
    Send Lloyd Chip Lambert:
    Default Re: Faria RPM Gauge does not "zero"
    Guys, my Tach doesn't work at all and it is stuck on 600RPM. I am going to try the fix above before I take the plunge and return it to Faria. Thx.
    I'VE GOT THE "ITIS" - 1996 210Z Shabah 5.7 LX - Opinions VernB63 Original Mariah Talk 5 04-17-2008 07:00 AM
    For Sale: Power seat slider for you "Z" owners mikeyt Mariah Parts For Sale & Wanted 1 03-05-2008 08:47 PM
    There are 259 users
