Tach not working
Old 06-22-2009, 12:24 PM   #1
John Michael Myers is currently offline
Send John Michael Myers:
Question Tach not working
I just purchased a 1999 Mariah 2001 Shabah in mint condition. The only problem I have is that the tachometer is not working. Does anyone know of the troubleshooting steps I should go through? I'm not sure if there is a fuse in line I should check. I did not get a owners manual with the boat.
John Myers "Tennessee"
  • Old 06-22-2009, 01:18 PM   #2
    Z 202's Avatar
    Z 202 is currently offline
    My Model: Mariah Shabah 202
    My Engine: 5.7L Alpha 1
    Send Z 202:
    Default Re: Tach not working
    There is a switch on the back to select the # of cylinders. This often gets corroded. Turn it a few times to see if that cleans the contacts. Make sure to set it back to the correct setting for your engine.
    Failing that, it could be wiring for the gauge itself. Faria gauges have a lifetime warranty so for a nominal fee you can return it for repair/replacement. There is a contact link for warranty repair on the Faria website.
    My Mariah
    Old 06-22-2009, 10:49 PM   #3
    Mike S is currently offline
    Send Mike S:
    On my 1998 shabbah 210 my tach seems to read high if you tap it while going it goes up down, every where it shouldn't be. I'm guessing its a tach issue?
    Old 06-23-2009, 01:10 AM   #4
    Sure does, just do like Z 202 suggested and that should get it working correctly!
    Old 06-30-2009, 07:46 PM   #5
    Billyclub is currently offline
    My Model: 1999 Shabah 182 Mercruiser 3.0L
    Send Billyclub:
    I had the same problem on my Shabah 182. Contact Faria via their website and request a repair authorization. They will tell you to send in the faulty Tach and a check for $30.00 and you'll get a repaired or replaced Tach. There is a lifetime warranty on Faria Tach's.
    Clock not Working '97 Shabah coxgreen Original Mariah Talk 0 04-29-2009 09:16 PM
    Cabin Lights not working Daxgirl Original Mariah Talk 1 04-28-2009 04:07 AM
    Fuel gauge not working kingtide Original Mariah Talk 5 07-26-2008 06:34 PM
    rev counter not working craig Original Mariah Talk 3 05-13-2008 12:31 PM
    Front Speakers not working... Z272 Original Mariah Talk 4 05-05-2008 05:57 PM
    There are 297 users
