Carb Adjustment 1992 Mariah 4.3 Litre
Old 06-29-2009, 06:03 PM   #1
seapoo is currently offline
Send seapoo:
Default Carb Adjustment 1992 Mariah 4.3 Litre
What are the adjustments for the two screws on front of carb? Rochester Quadrajet.
  • Old 06-30-2009, 12:26 AM   #2
    Default Re: Carb Adjustment 1992 Mariah 4.3 Litre
    Hi seapoo,
    They are the idle mixture screws. I suggest you leave then alone unless you're familiar with the procedure for adjusting them, To perform the adjustments correctly, you need to have the ignition in "Base Timing Mode" first. The procedure is explained in section 5C starting on page 12 of the Mercruiser 4.3L service manual.
    Old 06-30-2009, 12:42 AM   #3
    Send seapoo:
    Is there a default adjustment to start off with? Motor was smoking at idle after Marine adjusted both screws. They had them 3 turns out. I put them to 1.5 turns out and now it idles great with no smoke. Just want to ensure I have them at factory settings. Please advise.
    Old 07-01-2009, 12:45 AM   #4
    SEMIJim's Avatar
    SEMIJim is currently offline
    My Model: 182 Barchetta
    Send SEMIJim:
    Holy smokes! They were still making those in the '90s?!?! First thing we used to do with those, back in my late-60s, early-70s Woodward Ave. street-racing days, was either remove the vacuum controls on them (and then carefully adjust the linkages) or replace them with Holly carbs. We used to call them "Rochester QuadraJunks." I hope they're not as much trouble as they used to be. They worked well when they were working right. Problem was keeping them working right.
    If I recall correctly: One screw would be the idle mixture and the other the low-speed mixture.
    I tore-down and rebuilt those a couple times, back in the day.
    Jim
    Old 07-01-2009, 08:14 PM   #5
    Hi seapoo,
    Wow, three turns, huh... that way too much. I would seek another mechanic who knows what their doing! The manual says to start with the screws 1.25 turns out to start, so your right in the ballpark! To adjust them as best as possible, follow the manual's procedure.
    BTW, Per the manual, the carb is a Weber, not a Quadrajet four barrel, although they look the same. Oh, and SEMIJim, on the four barrel Webs and Quads, the two screws in front are the idle mixture screws for the front two bores (see carb exploded view, Pages 5C-18 and 19) and I was Holly man too except for some reason, I've got an Edelbrock Quad on my '70 Mustang, go figure...
    Old 07-01-2009, 08:59 PM   #6
    SEMIJim's Avatar
    Send SEMIJim:
    Oh, and SEMIJim, on the four barrel Webs and Quads, the two screws in front are the idle mixture screws for the front two bores (see carb exploded view, Pages 5C-18 and 19) ...
    I stand corrected. It's been a long time
    Jim
    Old 07-01-2009, 09:38 PM   #7
    I know what you mean Jim, A LONG TIM AGO for me too, but I still remember them well, I think...
    Remember American Graffiti? That Mel's Drive-in was in my old home town, I can still recall the Car Hop Girls!
    A getting older WetWilly
    1992 Mariah 2000Z depman160 Original Mariah Talk 12 04-03-2014 03:54 PM
    Docking light adjustment? ckgreenman General Maintenance 10 07-10-2009 10:09 PM
    new guy gere....with a 1992 mariah diablo 420-420 Original Mariah Talk 1 05-26-2009 12:26 AM
    1992 MARIAH MX 19 for sale texasowner Mariah Boats For Sale & Wanted 0 01-07-2009 01:51 AM
    There are 293 users
