rev counter not working
Old 05-12-2008, 08:13 PM   #1
craig is currently offline
Send craig:
Default rev counter not working
Hi everyone Northern Ireland here and its not raining so getting great time out on the water of Lough Neagh , I am having a problem though with my Rev Counter
ITS NOT WORKING does anyone have any ideas .i have checked with a circut tester and the light goes on but i have no movement .
Its a 2001 Mariah sx18 4.3 mercurser with a Mariah marked rev counter
any help would be appreciated
  • Old 05-12-2008, 09:35 PM   #2
    Hi Craig,
    Welcome aboard. If you do a search on this forum you'll find several posts dealing with faulty rev counters. For future reference, we here in the states call them tachometers or tach for short.
    Anyway, if you can get access to the back of the rev counter you will find a small dial or set screw. It should be currently set to the 6cyl position for your engine. The contacts for this dial commonly get corroded, so turn the dial or set screw back and forth several times to clean off the contacts and return it back to the 6cyl setting. Try this and let us know if it works.
    Good luck,
    Old 05-13-2008, 07:29 AM   #3
    Send craig:
    thanks Will i will try and let you know outcome
    why do you call it a techometer does it count Tecks per min
    only joking so dont take it to heart we have always called them Rev counters here
    so point taken
    thanks for Advice
    Old 05-13-2008, 12:31 PM   #4
    180diablo's Avatar
    My Model: 1993 Diablo 180
    Gallery Images: 30
    Send 180diablo:
    Here is an article I found on Wikipedia's webpage...
    http://en.wikipedia.org/wiki/Tachometer
    Keep us posted on your gauge issue.
    ~ Ryan
    Owner of the 3.0L Powerhouse!
    Front Speakers not working... Z272 Original Mariah Talk 4 05-05-2008 05:57 PM
    There are 299 users
