Trim switch on throttle
Old 07-07-2022, 10:41 PM   #31
Default Re: Trim switch on throttle
Originally Posted by CocoJoe View Post
1995 Mariah Talari 180 /3.0 . I’m having an issue raising the outboard … it won’t raise out of water? I hit the throttle trim up it won’t raise when it’s down. The trim works on water. I was able to jump the solenoid on pump/motor to raise the outboard. Is there something I’m not doing correctly to raise the outboard with the switch??
I think i answered your question over on the Facebook group but in the event it was someone else, your 'up' solenoid needs replacement and you may as well replace them both while you're at it. Here's a link to to the troubleshooter and wiring.
Bushcaddy likes this.
CocoJoe (07-08-2022)
    throttle lever puzzle deblynlea Original Mariah Talk 4 09-25-2023 12:51 PM
    Throttle Control - Mercury recall bdbyrnes Original Mariah Talk 2 09-02-2011 08:39 PM
    Throttle Body Restriction?? Jeff Barnett Mercury MerCruiser 13 08-31-2011 02:20 PM
    Throttle and shifter question.. Jeff Barnett Original Mariah Talk 3 09-19-2007 12:30 AM
    There are 261 users
